Fuel system discussion
Dzchey21
wyoming
Ok guys, i have been thrown some ideas on some new threads this is going to be for fuel systems only, both low and high pressure, injectors ect. What we are looking for is pump/injector combos, post data like rail pressure with pulse width or tune, and even better HP/Dyno numbers, or track numbers. Keep it on track, im not going to ask you more than once...
I want to keep these theads as short as possible so people dont have to wade in 10 pages of BS to get 1 post of good info
Dzchey21
wyoming
Im going to start off.
60hp nozzles Elite modded pump. Maintained 20k rail pressure with 2.25ms of pw (xrace at the time 2010) maintained full 24.5k rail pressure with 2.0 (x street, 310 tunes)
110hp nozzles (60%) Stock pump... 18k rail pressure @ 2.25 ms pw dyno'd 617 hp bone stock ford pump
110hp nozzles dual fuelers, maintained 24.5 rail pressure @ 2.25 ms of pw, track times are in the 650-675 hp range with some other issues, but you get the idea.
*** all set ups running an air dog fuel system with custom fittings and distribution block at the engine, maintained 5 psi of pressure to the pumps.
bigrpowr
<How I Fly
Administrator
craig said elite/rudys dual pumps and 100% 6 hole nozzles maintained 25k no problem today.
Craig@MFI
I have Rudy's dual fuelers 6hole 100% nozzles and airdog 165 with airdog upgrade and can hold 13.4 psi low pressure down the track and 25k rail pressure
mike@haller's
Cheyenne, Wyoming
Mal Burnsides truck runs Elite 110's, Industrial Dragon Fire single pump. Elites low pressure fuel system set at 15 psi. Maintains 24,600 rail at 1.9 pw. 917hp
White_monster
The great white north
My truck with 60's, ported rails, stock hpfp, and Elites stage 2 LPFS maintains 24,600psi on xstreet( tune from march 2011 ), maintains 23,400psi on xrace( tune from march 2011). Unsure what the exact pulse width's are but I think xstreet is 1.9 and xrace is 2.26. HPFP has 60,000miles on it as well.
Dzchey21
wyoming
Finnally i get to.report
Elite dual fuelers air dog 150 to an elite fuel block. No regulator on the return side
Maintains 24800 on xrace and gear head tunes with 2.23 - 2.29 Ms of pulse width with elite 150 injectors
Klutch
Elite 150 nozzles, lpf system, dragonfire, 24,500psi on recent xstreet, not sure of pulse width, haven't looked.
Klutch
I'm not saying it will. This is on xstreet so far. I'm having good luck, but have heard that it won't keep up. I will find out more in the spring.
Craig@MFI
should i was running dragon fire with 100% nozzles and held full rail pressre on xstreet and i think the 150hp elite tips are a little smaller so it should hold
Dzchey21
wyoming
Depends on what version of xstreet he has, some have 2.0 some have 1.75, so pw is very important when reporting
I would be curious to see if it keeps up on xrace, keep us posted im very curious to what its got, im sure its going to be asking alot of that pump.
And craig you are right 150s are about 85% nozzles
Erikclaw
Central CA
I will jump in here too. Custom KEM 345, Elite HP & LP, II pump, ported rails, 110hp nozzles, I am pretty sure it holds 24,500 or so. Will have to check and report.
What is pulse width under in the DD? I tried looking once but what I was reading didn't make sense.
