6.4 cam questions//help
krasselt21
I have a 2.6 smooth bore 6.4 pull truck. No matter what gear ratio: 4.88,4.56,4.30, or 4.10 truck will only turn 3600 rpm. Stage 4 rcd cam. Ported heads. 100 over injectors. Ported intake manifold. Looking for some help. Tried different tuning already. Is it head flow would overdose valves help?
powerstroked08
Pennsylvania
Really? I'm running 5,500 with a zf6 in high range second (labeled 1 on the shifter) with 3.73's on 35's.
Sent from my SM-G950U using Tapatalk
powerstroked08
Pennsylvania
Wow. Something is off then. I mean I was able to hold 4300-4400 down the track with stock fuel on 76/59 chargers. That was before I bumped my build up to what it is now.
krasselt21
Yeah it’s holding rail. Also only 2.6 smooth bore single. Wondering if stage 4 rcd is to much and if it’ll perform better on less of cam
krasselt21
Ported heads, ported intake manifold, dual fuelers, 1000% over injectors, cut coated delipped pistons, bd manifold, bd up pipes, Midwest s400 turbo pedestal, RCD stage 4 cam
powerstroked08
Pennsylvania
I really doubt it is head flow issues. And by running oversized valves it can actually hurt you a little bit. Because of it shrouding the valves. The porting helps out for sure, not like a gas job but it helps none the less. What does it do? Will it free rev to 4k? Or is it more of a load thing that it won't come up to the top end? Are you able to data log? Sorry for all the questions, but we need to know a little bit about what it's doing.
krasselt21
no matter the gear ratio on the track, it will only turn 3600 rpm. it will free rev past no problem, it will go past on a dyno, just doesn't do it on the track. so I wondering with the load and the bigger cam if that is hurting it or not. trying to get it figured out for the spring.
Have you tried pulling back pulsewidth and seeing if anything changes? What if you drive it down the track with no sled behind, will it pass 3600?
powerstroked08
Pennsylvania
Hmmm seems strange. Have you played with the timing in the upper rpms to compensate for the cam and bigger piston bowl? Because that cam should move your power band up higher in the rpm range, And sacrifice some low end. And like sootie said, try pulling some fuel back and se3 if you're choking the charger out some.
krasselt21
itll turn 5000 rpm just drive down track. its as soon as its loaded on track it seems. as on dyno I can run it up to 4500. but the power band on the came maxes out at like 3500 and doesn't make sense to me.
do you have any videos showing what the smoke looks like?
