2017+ NL Intake , H&S Cold side pipe
DieselJpower
Weeki Wachee FL
3k miles on them
Powder cated black pro guard 7 with blue pre filter
Cold side pipe has the butterfly dereete and is tuning required
350 shipped on the intake
175 shipped on the H&S pipe
DieselJpower
Weeki Wachee FL
The NL is designed to connect at the stock upper intake manifold. I could maybe have chopped the mpd intake pipe to connect it with the no limit but said screw it. MPD filter is a bit larger too.
The under hood is very much the same as the pre 17 trucks except the passenger battery and the air intake switched spots. I love the way the pipe kit cleaned up that plastic nonsense. $80k truck with a plastic manifold WTF
Thanks man, got any plans for your new plati ?
Just swap intake and ouo traction bars over and get a set of tunes for the x4 that i have in the old one. Thats pretty much it. Basically make it the same as the old one with a few more pony's due to the fuel pump and spinny thingy being better.
Will either the absolute pipe or the H&S pipe work on 11-16 trucks?
Dieselfanatic
Bottom dollar on intake? Don’t NEED it but would prefer to run it rather than the stocker till my piping kit if done being built.
