Go Back   PowerStrokeArmy > Power Strokes > 6.7 Aftermarket
Reply
Thread Tools Display Modes
  #1
Old 02-27-2019, 11:01 AM
kingranchstroker's Avatar
kingranchstroker kingranchstroker is offline
Sergeant
Member's Gallery
Default MPD Quick Spool Budget kit
Anyone running one of these kits on a 11-14 with stock fuel? Im curious in hearing the pros and cons vs the standard S363 budget kit with stock fuel.
__________________
2012 F250 CC/SB Lariat Ultimate
SOLD: 08 F250 CC/SB KingRanch
SOLD: 04 F350 CC/SB KingRanch
RCD 190/100s, MTW M3
8000# 12.5 @ 106.9mph
  #2
Old 03-26-2019, 09:21 PM
Sergeant
Member's Gallery
Default
After talking with Mpd, No Limit, and Flynn shop, Iím between the S362sxe and the S363sxe. Iím just not sure which turbine would be best with the stock 12í injection pump. Obviously the 68 turbine will spool faster than the 74, I just want to make sure I wonít run into drive pressure issues with the 68. Iím running 35s with the 3.55 rear at sea level most of the time. Iím looking for the best spool for daily driving and towing. Iíve never had a non vgt so just trying to pick the best one the first time. Thanks in advance for any input.
__________________
  #3
Old 03-27-2019, 07:28 AM
Zeb Zeb is offline
Lieutenant
Member's Gallery
Default
Quote:
Originally Posted by kingranchstroker View Post
After talking with Mpd, No Limit, and Flynn shop, I’m between the S362sxe and the S363sxe. I’m just not sure which turbine would be best with the stock 12’ injection pump. Obviously the 68 turbine will spool faster than the 74, I just want to make sure I won’t run into drive pressure issues with the 68. I’m running 35s with the 3.55 rear at sea level most of the time. I’m looking for the best spool for daily driving and towing. I’ve never had a non vgt so just trying to pick the best one the first time. Thanks in advance for any input.
Stock fuel 6.7 is enough fuel to get into the low 500 hp range.
I don’t have a 6.7, but I have done a bunch of non-vgt 6.0’s in that hp range. I really like an SXE 63/68/.83 or SXE 64.5/68/.83 at that power level for daily driving, some towing, and having fun. Drive pressure starts to climb fairly quickly over 3,200rpm on a setup like that, but that is a trade off for good drivability in the rpm range where we spend the majority of the time.
The 6.7 has a few more cubic inches, and better airflow capabilities (compared stock to stock) than a 6.0, so it is going to drive the turbo harder/ better/more efficiently.
If I were in your shoes, I think I would go with an SXE 63/68/.91.
Good tuning will definitely help.
  #4
Old 03-27-2019, 07:06 PM
Sergeant
Member's Gallery
Default
So you think having the 63/68 in the .91 housing should keep drive pressure in check while still giving the best spool?How much slower would you think the 62/74/.91 would spool. Obviously with the 74 the drive pressure shouldnít be an issue. And realistically there isnít much of a power difference between the 62 and 63 since the 62 flows so much... I canít find info or videos for that matter of these chargers on 6.7 Powerstrokes. No real world numbers or in cab videos of spool up and normal driving. All sorts of info on Cummins but that does me very little good. Thank you for your insight.
__________________
  #5
Old 03-27-2019, 11:10 PM
Zeb Zeb is offline
Lieutenant
Member's Gallery
Default
What everyone calls a 62 actually measures 61.47mm, so the sizes are pretty evenly spaced. (61.47mm, 62.99mm, 64.4?mm)
Turbine size will make the biggest difference on spool up.
It takes 2 things to drive a turbo, heat and pressure. Ask yourself how much of the time you will spend at an rpm level that can cause back pressure to be high. The time you spend there will be minimal compared to the time you spend at lower rpm when daily driving and towing where spoolip will be WAY more important.
Most guys spend way too much time worrying about whether drive pressure will be 1/1. If you hit 1.5/1, or even a little more, at the top of a shift, or pulling a hill for a bit, ITíS NOT GOING TO HURT ANYTHING as long as egt, etc is within the safe zone.
  #6
Old 03-28-2019, 05:48 AM
Sergeant
Member's Gallery
Default
That makes perfect sense! I couldnít tell you the last time I matted the go pedal. Which is sad cause I used to run the dragstrip all the time in my 6.0. Anyhow yeah you make perfect sense cause the truck gets up to speed plenty fast 2500rpm and under. Thank you Zeb for your insight.
__________________
  #7
Old 03-29-2019, 09:44 AM
doo dah's Avatar
doo dah doo dah is offline
Sergeant
Member's Gallery
Default
I have a 2012 with an S363 but not sure if it is SXE. It is a 63/68 from Industrial though. I have stock fuel and TSD got 576 with a leak on the stand pipes so boost fell off around 27 lbs so might be around 580 since fixed and able to get 32 lbs. I've had mine on for around 50k miles with a lot of in town, highway, and towing 15k+ lbs and like it quite a bit. I have learned to drive around the shortcomings in low boost conditions and do just fine. EGTs have only hit 1400 on some 7% grades over 7,000 feet sea level, otherwise right around 900-1,000 towing heavy.
__________________
2012 F350 CC LB 4x4 Lariat. MiniMaxx with TSD tunes, 5" exhaust, Industrial Injection S363 single turbo kit.
  #8
Old 04-15-2019, 09:15 AM
Mr_diggs Mr_diggs is offline
Private
Member's Gallery
Default
I’ve got a s363sxe on my ‘13 with stock fuel. I’ve been waiting for my tuner (a very well known guy) to revise my tunes for non-vgt. Haven’t gotten a reply from him in a month so I can’t give you a good review. It’s too bad my $$$ didn’t buy me any customer support....
  #9
Old 04-15-2019, 03:38 PM
Tom@BigTimeKustomz's Avatar
Tom@BigTimeKustomz Tom@BigTimeKustomz is offline
Sponsor
Member's Gallery
Default
I'm running the 364.5 SXE on my 2013 with stock fuel. It runs amazing, I'm super happy with it. Probably going to go 15+ CP4 this year and then it'll be done. Turbo spools great, can be smokey if I want it to be, but it's a lot of fun to drive. Night and day difference for sure.
__________________
Big Time Kustomz Diesel and Off-Road Performance
2013 F350 CC/LB - Sterling Gray, Lariat Ultimate, 22X12 FF19's, Toyo Rubber, MPD 364.5 Turbo with Piping Kit, iPad Dash kit, Amp Steps, Bilstein Suspension
Contact me for great pricing on the industry's leading products tom@bigtimekustomz.com
  #10
Old 04-15-2019, 04:27 PM
Zeb Zeb is offline
Lieutenant
Member's Gallery
Default
Quote:
What turbine and turbine housing?
  #11
Old 04-15-2019, 05:48 PM
Sponsor
Member's Gallery
Default
.91 turbine
__________________
  #12
Old 04-15-2019, 05:49 PM
Zeb Zeb is offline
Lieutenant
Member's Gallery
Default
.91 turbine
Which turbine? 68/76 or 73/80?
  #13
Old 04-15-2019, 05:52 PM
Sponsor
Member's Gallery
Default
68/76
__________________
  #14
Old 04-15-2019, 07:06 PM
Zeb Zeb is offline
Lieutenant
Member's Gallery
Default
68/76
Awesome, thanks!
  #15
Old 04-16-2019, 05:23 PM
Private
Member's Gallery
Default
Whoís tuning do you use? I canít seem to get my tuner to send revisions so Iím looking elsewhere.
  #16
Old 04-17-2019, 03:55 AM
Sponsor
Member's Gallery
Default
I'm running Anarchy on my truck.
__________________
  #17
Old 04-19-2019, 11:34 AM
Sergeant
Member's Gallery
Default
At what rpm would you say your 64.5/68/.91 starts to spool?
Iíve had my eye on 363/73/.91. I figured I would go with the 73 turbine since h&s and mpd both choose to use them for their kits.
__________________
  #18
Old 04-19-2019, 11:40 AM
Sergeant
Member's Gallery
Default
Quote:
When I get my budget kit. I was told call Midwest. Sounds like they have some of the best non vgt tuning around.
__________________
  #19
Old 04-19-2019, 11:48 AM
Swaan's Avatar
Swaan Swaan is offline
Lieutenant
Member's Gallery
Default
That's not necessarily true. Mpd have the 68 turbine on there quick spool kits. I think if your not looking for over 500 hp and want better drivability the 68 turbine is the way to go.
Heck didnt mpd make over 600hp with a 62mm precision not long ago. I think it only had there high flow 66mm turbine.
__________________
E97 f250 ECLB. SOLD!
Dana 60 front with rsk kit. 5" blocks in rear. 4:10 on 35s. Blackwater reman 7.3 with arp studs , comp springs. 175/80 pis inj, adrenalin hpop,irate fuel system with fuel lab pump. Borg warner 364.5 fmw with 1.00 a/r housing. EC450 horton electric fan clutch. ZF5 shaker.
--16 f350 ccsb lariat 6.7 tuned and D-leted!!😈
--15 VW passatt TDI sport. Tuned and D leted 6 speed
  #20
Old 04-19-2019, 04:59 PM
Sponsor
Member's Gallery
Default
I’ve had my eye on 363/73/.91. I figured I would go with the 73 turbine since h&s and mpd both choose to use them for their kits.
It's pretty low RPM I'd say. If you want to PM me your number I can text you some driving videos. The piping kit made it spool faster over the factory stuff. I'm super happy with the turbo. Let me know if I can get one headed your way.
__________________
  #21
Old 04-20-2019, 05:39 AM
Sergeant
Member's Gallery
Default
When I talked to one of the guys at mpd he was very adamant on sticking with the 363/73/91. I asked about maybe going with the 362 but he said the 363 is much better, but really never told me why.
__________________
  #22
Old 05-20-2019, 09:29 AM
curtis270 curtis270 is offline
Corporal
Member's Gallery
Default
im looking at this kit as well is really like the kit just having a hard time dealing with the price due to being able to buy the turbo for 600 ish bucks. I had the 63/68/91 on my 5.9l then switched to the sxe 369. with stock fueling on my 6.7 powerstroke and just ******s and a intake im leaning towards the 63. just wish someone could explain the extra 2100 bucks without the piping
  #23
Old 05-26-2019, 04:54 AM
ccraver ccraver is offline
Private
Member's Gallery
Default
I just installed the MPD budget 64.5 sxe on my 13. Overall I'm happy with the performance. The only complaint I have is that it is quite a bit laggy city driving it. I haven't installed a piping kit yet which I'm told will help out a bunch. I'm running tyrant tunes that have been redone for the non vgt set up. I'm really wanting to do fuel next.
  #24
Old 05-26-2019, 04:55 AM
Private
Member's Gallery
Default
Quote:
I thought the exact same thing. I can't see how the piping for the turbo cost $2100!!
  #25
Old 05-26-2019, 01:40 PM
jcain jcain is offline
Major
Member's Gallery
Default
You mean the custom uppipes, downpipe and pedestal?
__________________
2016 F350 CC-DRW Fx4, Tow Boss, Monochromatic King Ranch
Ezlynk 2, Fox 2.0 resis, Pmf Fox 2.0 DSS, OUO ALA, OUO spring thing, OUO traction blocks & bars, AL 5000 ultimate + wireless one, AMP steps, Retrofitted Projectors, Midwest comp 3r trans with Precision converter, HhS triple turbo kit with PTE 6870s, H&S dual fuelers with RCD 100% injectors,
  #26
Old 05-26-2019, 02:05 PM
DieselJpower's Avatar
DieselJpower DieselJpower is offline
Lieutenant
Member's Gallery
Default
As well as coated as coated, custom machined/welded compressor cover
Not to mention R&D and time involved in production.
Compare that to a fancy vgt that's about $3k that comes with nothing else and has a core charge, you're getting a pretty good deal
__________________
Josh
02 CCSB F350 4x4 -- GONE
04 Excursion 4x4 -- GONE
05 Excursion 4x4
19 CCSB F350 4x4
19 CCSB F350 4X4
  #27
Old 05-29-2019, 07:01 AM
Corporal
Member's Gallery
Default
Quote:
what made you decide on the 64.5 over the 63?
  #28
Old 06-01-2019, 03:14 AM
Private
Member's Gallery
Default
Local diesel shop owner suggested it. I think I would have been happier daily driving the 63 but I wouldn't have been as happy with the total power of the 63. I'm installing a piping kit next week. I'm really hoping that helps with the lag.
  #29
Old 06-01-2019, 07:34 AM
08Monster's Avatar
08Monster 08Monster is offline
Major
Member's Gallery
Default
Ditch the tyrant tunes. Mine runs way better with TSD tunes.
Sent from my moto z3 using Tapatalk
  #30
Old 06-01-2019, 10:46 PM
Private
Member's Gallery
Default
Are you running the same mods and turbo as I am with the TSD tunes?
  #31
Old 06-02-2019, 10:26 PM
08Monster's Avatar
Major
Member's Gallery
Default
I've got a 63, full piping kit and dual fuel. I have tyrant tunes and TSD tunes, the TSD are way better. Tyrants trans tuning on mine was so terrible it should have been a crime.
  #32
Old 06-03-2019, 07:22 AM
Corporal
Member's Gallery
Default
how much is a tune from TSD?
  #33
Old 06-03-2019, 10:04 AM
08Monster's Avatar
Major
Member's Gallery
Default
I believe $650 for Ez-Lynk but I am not 100% sure on that. And it'll be a SOTF tune.
  #34
Old 06-03-2019, 11:06 AM
Corporal
Member's Gallery
Default
thanks
  #35
Old 06-03-2019, 09:09 PM
Private
Member's Gallery
Default
$650??!!! That seems crazy high for tunes. I think I paid $350 for tyrant tunes for my SCT X4 and SOTF.
  #36
Old 06-03-2019, 09:17 PM
08Monster's Avatar
Major
Member's Gallery
Default
And this is Ez-Lynk. Gotta pay the most to have the latest and greatest.
  #37
Old 06-08-2019, 06:46 PM
Motostroker's Avatar
Motostroker Motostroker is offline
Major
Member's Gallery
Default
EZ Lynk was the best upgrade Iíve ever done. Itís worth the $$
Sent from my iPhone using Tapatalk Pro
  #38
Old 06-10-2019, 04:10 AM
Private
Member's Gallery
Default
Whats the deal with the ez link? Why do you like it so much? I noticed your post that you put in the classifieds. I just installed a 64.5mm MPD budget turbo on my 13 and am not very happy with the towing performance of it and I'm not even towing that heavy of a load. I have tyrant tunes loaded by an sct x4 with SOTF. Did you ever get your towing issue resolved?
  #39
Old 06-10-2019, 07:26 AM
Major
Member's Gallery
Default
Itís all in the tuning. EZ Lynk provides a better platform and more Parameters to adjust.
The new tunes I just order work far better then my old ones. Shift points and converter lockup points are key to make sure a non VGT charger doesnít fall on its face.
Donít get me wrong, 4:10 gears help too, however tuning helps just as much
  #40
Old 06-10-2019, 09:18 AM
Major
Member's Gallery
Default
There's no more or less tunable parameters across the many devices.
__________________
  #41
Old 06-10-2019, 09:44 AM
Private
Member's Gallery
Default
What tunes did u go with?
  #42
Old 06-10-2019, 06:12 PM
Major
Member's Gallery
Default
Quote:
I wasnít aware of that, Iím going from info told to me by a previous tuner.
  #43
Major
Member's Gallery
Default
Proven
  #44
Old 08-02-2019, 05:42 PM
Sergeant
Member's Gallery
Default
What turbine did you go with on your 64.5? Iím between the 63/68/.91 and the 64.5/68/.91. Curious what the difference in lag/spool will be with the piping kit between the two?
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
Designed by Military Ltd
