Go Back   PowerStrokeArmy > Power Strokes > 6.7 Aftermarket
Reply
Thread Tools Display Modes
  #1
Old 03-29-2019, 08:35 AM
HobbyStock62's Avatar
HobbyStock62 HobbyStock62 is offline
Sergeant
Member's Gallery
Default Getting a 6.7, what to do first?
Im sure this has been asked a lot, just dont have time to search pages of forums. Going to be getting a 2014 or 2015 6.7L within a couple weeks here. I am looking to get some things ordered so that when I get the truck, I can just bolt some stuff on, throw a tune on and go. I know the 6.0 crap, but this is all new. What im looking for is what everyone is going for/what the best is for all the ******s, and tuner. Any other recommendations? Again, I know this is basic stuff that I could research but am juggling a bunch of crap, and am just looking for a guy that knows to tell me get this, this and this basically. Thanks in advance.
__________________
I am a ginger.
  #2
Old 03-29-2019, 08:36 AM
7.3obs's Avatar
7.3obs 7.3obs is offline
Sergeant
Member's Gallery
Default
Subíd
__________________
Black truck. Studs, beehives, push rods, stealth duals, s472sxe,350/200's, bts, ge@rhe@d tuning.
White truck, Winter/work truck/sled hauler, flat bed. 6637 filter. Ts performance chip. Dana 60. 5inch diamond eye exhaust.
2011 6.7 f350. 37xxx. 20x12 -44 305/55ís. Leveled
  #3
Old 03-29-2019, 08:53 AM
Sergeant
Member's Gallery
Default
They literally *** out d.e.l.e.t.e.s now? dafuq.
__________________
I am a ginger.
  #4
Old 03-29-2019, 09:45 AM
PSDJunky's Avatar
PSDJunky PSDJunky is offline
Private
Member's Gallery
Default
Yeah, the *** are pretty cool huh.
Get a 15, not a 14, for the slightly improved HPFP, injectors, main bearings, turbo, & maybe a couple other things. I had an 11, got a 14, wished I had a 15 but not worth restarting a loan, CCV house routing caused excessive turbo back pressure & crankcase pressure, formed oil droplets (not drips), traded into a 19, & I'm tickled to death. FYI, incase ya don't know, a Lariat Ultimate has basically all the bells n whistles of a King Ranch or Platinum. You'd miss out on a few little things, but nothing major...depending on your color and trim preferences and pricing.
I suggest C C V (do not kink or block hose at all or allow dips within hose routing if in very cold environment), E G R, D P F, G D P's E z L y n k toons, intake, Air D o g or F A S S if ya want the added fuel cleanliness (like I do)/not needed for pressure at entry level power levels. There's also a thing called a HPFP Disaster Prevention Kit that I highly suggest. I'll just let ya Google it or call someone about it. Otherwise, oil at 5k intervals, fuel at 15k, trans/xfer case/diffs at 60k (I swap filters and fluid at 30, flush at 60, & alternate from there), follow coolant checks, etc. I bet some folks would say that's a lil overkill. But IIRC, a Scorpion runs about $13k & a 6R140 runs about $7k. So, I do my maintenance slightly on the early side. Otherwise, enjoy the greatness that is a 6.7L PSD.
  #5
Old 03-29-2019, 02:47 PM
Sergeant
Member's Gallery
Default
Thats exactly what I was looking for, thanks. Is the tuning "change on the fly" fine on these trucks? I know that was a no go for the 6.0s, but I suppose technology has come a long ways since I was dealing with all that on my 6.0.
__________________
I am a ginger.
  #6
Old 03-29-2019, 04:08 PM
PSDJunky's Avatar
Private
Member's Gallery
Default
No prob, glad it covered what you were looking for. I used S O T F quite a bit with G D P's toons on the Ez L y n k & never had a problem. I'll soon be using the same setup on my 19, plus their monitor. Using your phone is okay. But, I got tired of putting it in and getting it out of the mount every time I got in or out of my truck. They have a S O T F switch that mounts where your OBDII port is or you can switch via their monitor, btw. ... very easy to use, great customer support, tons of great toons, nice monitoring layouts
  #7
Old 03-29-2019, 06:44 PM
sootie's Avatar
sootie sootie is offline
General
Member's Gallery
Default
Disaster prevention kit is snake oil-skip it. No need for a low pressure fuel system, stock can handle 750hp easy. Go for 15+ as they have a better turbo and larger hpfp
  #8
Old 03-29-2019, 09:33 PM
lincolnlocker's Avatar
lincolnlocker lincolnlocker is offline
General
Member's Gallery
Default
My 12 got better mpg than the 15 i have now but the new tunes i have with 2nd gear lock up flat out hauls ass! Prior to that, it felt like my 12 ran better. Not now though. What junky said about maintenance intervals is spot on though.
__________________
00,f350,4x4,cc,drw. Sold... good bye ole girl. I will miss you
15,f350,4x4,cclb, not stock
  #9
Old 03-29-2019, 11:34 PM
C2tuck's Avatar
C2tuck C2tuck is offline
Lieutenant
Member's Gallery
Default
I sure like my TSD tunes on ez...trans shifting is perfect!
__________________
2015 CCSB F250 XLT FX4...American Force, Toyo AT 2ís, TSD tunes, EZ Lynk, 4Ē Flo Pro, Fox 2.0ís.
  #10
Old 03-30-2019, 06:16 AM
PSDJunky's Avatar
Private
Member's Gallery
Default
Quote:
Out of curiosity, because I like the multitude of posts I've seen from ya, why are you not a fan of the DPK? I like it for bang-for-buck assurance, but I have wondered how needed it really is/ what're the chances of getting diesel bad enough to shell out the pump and ruin your fuel system...my understanding & thoughts... but I'm curious to read your opinion, might adjust mine
Thanks man, I'm glad to know you approve of those intervals *no smart arse*... same about the posts. I agree with the 2nd gear TC lockup. G D P has several toons with that option and I'm a fan. I also really like their multiple stages of trans toons/ gear holding and line pressure increasing (not familiar with the other toons mentioned). Out of curiosity, did you have different gears in your 12 vs your 15? I think that may have something to do with the change in turbos. *always learning* My daggon 19 is considerably better stock than my 14 was stock (same 3.55s)... shocker ...really itching to get it tooned.
  #11
Old 03-30-2019, 06:28 AM
PSDJunky's Avatar
Private
Member's Gallery
Default
Quote:
Gave your post a lil more thought...
1. I guess it doesn't * tunes. I'll start spelling it right.
2. What year is your truck? I had a little bit of a lag at shift points with G D P. It's just that it didn't quite maintain aggressiveness throughout... almost like it was giving the trans a breath to grab the next gear... not annoying really, just noticeable, on my 14. But, I had a badly kinked C C V hose (excessive crankcase pressure and turbo back pressure, learned the hard way ). I wonder if that had anything to do with it... should probably ask G D P. For the OP's decision making, do you experience that with your tunes? What about lincolnlocker and sootie?
  #12
Old 03-30-2019, 06:45 AM
sootie's Avatar
General
Member's Gallery
Default
Dpk is only good if the failure is on the cam side of the pump which may account for more than half of the failures but certainly not all. Besides, if the lack of lubricity was enough to kill the pump, what do you think it's doing to the injectors? Sure it might keep metal out if them but it's not just metal that kills them!
  #13
Old 03-30-2019, 08:11 AM
PSDJunky's Avatar
Private
Member's Gallery
Default
Gotchya, I'll be running an Air D o g II 4G as well. My main concern was contamination, which is why the after market lift pump, that and purer fuel. My thought was basically $1k or so to avoid, from what I've been told, $12k potential damage... just as an added safety net, in combo with the lift pump
  #14
Old 03-30-2019, 09:05 AM
sootie's Avatar
General
Member's Gallery
Default
Quote:
Why reduce reliability with a Fass or air dog?????
Be money and reliability ahead to install an advanced filtration system in line, while keeping the factory pump. Far less likely to get stranded and you don't have to hack up OEM stuff. For example the diesel site setup....
  #15
Old 03-30-2019, 09:10 AM
PSDJunky's Avatar
Private
Member's Gallery
Default
Hmmm, okay, I'll check it out, thanks
  #16
Old 03-30-2019, 03:52 PM
6.0 Tech's Avatar
6.0 Tech 6.0 Tech is online now
Colonel
Member's Gallery
Default
I think co04cobra on here is selling one...
__________________
04 cclb IDP and TSD tunes, KC Stage 2 hi pressure, S476 atmosphere, Odawg Stage 2 ported intake, RCD Stage 1 cam, RCD lifters and pushrods, RCD 120# valve springs, ARP 625s, o ringed heads, Warren 7mm 250/100 hybrids, Strictly bowl dereete regulated return, Air Dog 2 4g, Snow stage 2 water/meth
  #17
Old 03-30-2019, 06:35 PM
PSDJunky's Avatar
Private
Member's Gallery
Default
Roger that
  #18
Old 03-30-2019, 08:36 PM
C2tuck's Avatar
Lieutenant
Member's Gallery
I honestly havenít noticed a difference at all between how the trans acted when stock. It seriously shifts dead on every time. No flaring, no lagging, just perfect shifting even when you bury it to the floor. Plenty of power, but the main reason I went with them was the trans shifting. Mines a 15 btw.
I too am about to add a dieselsites filter. Iím adding a fuel box aux tank/toolbox combo and will be getting diesel from oilfield locations. Hey..free diesel for the next few years should pay for all this stuff. Lol.
__________________
  #19
Old 04-01-2019, 07:08 AM
doo dah's Avatar
doo dah doo dah is offline
Sergeant
Member's Gallery
Default
I second the TSD tunes. Mine was dyno tuned with them and Chris made some adjustments because I have a full Suncoast built 750+ transmission. As for fuel filtration I have the factory lift pump supporting just over 575hp at the wheels with 237,000 trouble free fuel system miles. I'm with Sootie on the stock fuel being pretty darn good.
__________________
2012 F350 CC LB 4x4 Lariat. MiniMaxx with TSD tunes, 5" exhaust, Industrial Injection S363 single turbo kit.
  #20
Old 04-01-2019, 09:33 AM
PSDJunky's Avatar
Private
Member's Gallery
Default
Right on... I checked on the dieselsite system & it looks like I'll have to call and see if they have one for 19 trucks yet. That diesel setup is awesome though, clearly.
Quote:
Sounds good about OEM lift pump & the hint of what you're running.
  #21
Old 04-01-2019, 12:57 PM
Sergeant
Member's Gallery
Default
Wait, these things are making 575 on basic tunes/exhaust? Stock fuel and air?
__________________
I am a ginger.
  #22
Old 04-01-2019, 01:29 PM
sootie's Avatar
General
Member's Gallery
Default
Quote:
The guy you quoted has a non-vgt, but yes. 15+ trucks make around 580 at the wheels tune only. 11-14 trucks are around 500 tune only
  #23
Old 04-01-2019, 01:38 PM
Sergeant
Member's Gallery
Default
Wow thats impressive. I like it. Anyone have a company they like/recommend to order this stuff through?
__________________
I am a ginger.
  #24
Old 04-01-2019, 03:46 PM
PSDJunky's Avatar
Private
Member's Gallery
Default
Rudy's, CDT... probably mainly cause I have a good friend at Rudy's & CDT is about 30 min from my house
  #25
Old 04-01-2019, 04:09 PM
Zeb Zeb is offline
Lieutenant
Member's Gallery
Default
Jared at Midwest Diesel and Auto
  #26
Old 04-02-2019, 02:18 PM
General
Member's Gallery
Default
No limit fab.. mikey usually makes deals to good to pass up.
__________________
  #27
Old 04-30-2019, 02:44 PM
Sergeant
Member's Gallery
Default
So I put money down on a 2015 6.7 down in texas, flying out Friday to drive it back. Now, are all the 2015s the updated engine? Curious because its a earlyish 2014 build, but by the vin its a 2015.
__________________
I am a ginger.
  #28
Old 04-30-2019, 04:20 PM
sootie's Avatar
General
Member's Gallery
Default
Yes. Updated turbo setup and hpfp that is...
Engine changes came 17 model job 2
  #29
Old 05-01-2019, 06:15 AM
Sergeant
Member's Gallery
Default
Ok sweet, I just wanted to make sure it had the updates over the early years. I put some down on it, and then saw the build date and had a o **** moment.
__________________
I am a ginger.
  #30
Old 05-06-2019, 09:47 PM
jcain jcain is offline
Major
Member's Gallery
Default
The 15+ is all fine and dandy and everyone loves to point out the better turbo and pump but they almost always forget to mention the reduced clutch count in the trans.
__________________
2016 F350 CC-DRW Fx4, Tow Boss, Monochromatic King Ranch
Ezlynk 2, Fox 2.0 resis, Pmf Fox 2.0 DSS, OUO ALA, OUO spring thing, OUO traction blocks & bars, AL 5000 ultimate + wireless one, AMP steps, Retrofitted Projectors, Midwest built long block, Midwest compounds 66mmVgt PTE 86mm, H&S dual fuelers with RCD 60% iinjectors, Midwest competition 6r140, EE Billet faceplate, Suncoast quaddisc
  #31
Old 05-07-2019, 07:02 AM
General
Member's Gallery
Default
Quote:
Yep, true!
__________________
  #32
Old 05-09-2019, 04:11 PM
Sergeant
Member's Gallery
Default
Where is everyone mounting their EZ Lynk? Also the SOTF switch, they dont tell you where in the 5 pin plug the two wires go, or where the plug even goes. Anyone have some insight on that? And a place to stick that sucker too.
__________________
I am a ginger.
  #33
Old 05-09-2019, 05:04 PM
Tom@BigTimeKustomz's Avatar
Tom@BigTimeKustomz Tom@BigTimeKustomz is offline
Sponsor
Member's Gallery
Default
My EZ Lynk is tucked under the dash and zip tied up. My switch is also tucked under, I don't change the power level at all.
__________________
Big Time Kustomz-Diesel and Off-Road Performance
917-974-6349
www.bigtimekustomz.com
2013 F350 CC/LB - MPD 64.5, MPD Piping Kit, EZ-Lynk, Leveled, Fuel's
  #34
Old 05-10-2019, 11:16 AM
C2tuck's Avatar
Lieutenant
Member's Gallery
Default
Mine is in the little useless black compartment thatís by your right knee. I rarely change it either. Just leave it on 4
__________________
  #35
Old 05-10-2019, 12:11 PM
General
Member's Gallery
Default
Same place as mine!
__________________
  #36
Old 05-10-2019, 02:24 PM
J98 J98 is offline
Private
Member's Gallery
Default
Have there been a lot of trans issues in the 15-16 trucks vs the 11-14? Only asking as this is the first Iíve heard of it..
  #37
Old 05-10-2019, 03:00 PM
Major
Member's Gallery
Default
Yes
__________________
  #38
Old 05-10-2019, 05:13 PM
C2tuck's Avatar
Lieutenant
Member's Gallery
Default
Quote:
Depends I guess...
Some people on here beat the piss out of there trucks with no issues (Jomax). I havenít heard of many having issues on here.
__________________
  #39
Old 05-11-2019, 05:29 AM
HeavyAssault's Avatar
HeavyAssault HeavyAssault is offline
Major
Member's Gallery
Default
Quote:
Some people on here beat the piss out of there trucks with no issues (Jomax). I haven’t heard of many having issues on here.
Could it be that the torque convertor was improved over the 11-14 trucks? That's a point no one has ever been able to discuss, or just want to forget. I'd say the clutch count is a mute point since it's like 1-plate in one area and 1-plate in another area. It's not like the plate count difference between a gasser motor transmission and a diesel transmission.
  #40
Old 05-11-2019, 05:59 AM
sootie's Avatar
General
Member's Gallery
Default
Quote:
Are you aware of a difference in the tc's?
  #41
Old 05-11-2019, 06:37 AM
Major
Member's Gallery
Default
Yea....that's why I brought it up. Not to mention it's been addressed/asked in the past but usually followed by crickets which tells me people just don't know.
  #42
Old 05-11-2019, 09:23 AM
Major
Member's Gallery
Default
The 15+ absolutely show their weakness at 600rwhp, in regards to the trans, most commonly the 4-5 and 5-6 shift
__________________
  #43
Old 05-11-2019, 09:30 AM
Major
Member's Gallery
Default
The converters are different, but how would that affect an inability for the forward clutches to hold power? The converter isn't slipping it's the clutches.
__________________
  #44
Old 05-11-2019, 11:57 AM
Major
Member's Gallery
Default
Okay...so help me understand how the clutch plate break out between the Forward Clutch and Direct Clutch cause that problem since those are the only areas that have less(1 less Friction and 1 less Separator plate in each clutch to be exact) plates between the 11-14 trans and 15+ trans.
I'm not saying it's the convertor as the source of the issue...there's more parts causing the shifting then just those plates alone.
  #45
Old 05-11-2019, 01:39 PM
C2tuck's Avatar
Lieutenant
Member's Gallery
Default
So stay on the lower side of 600rwhp and your ok??
__________________
  #46
Old 05-11-2019, 01:57 PM
Major
Member's Gallery
Default
You answered your own question. One less friction.
__________________
  #47
Old 05-11-2019, 03:37 PM
J98 J98 is offline
Private
Member's Gallery
Default
A 11-14 isn’t close to 600 rwhp (tuned only) and that’s where a large majority of owners stop with performance mods... could also play into why there’s been more of ‘15-16 casualties
  #48
Old 05-11-2019, 03:50 PM
Jomax's Avatar
Jomax Jomax is offline
General
Member's Gallery
Default
Which shouldnít matter. My truck had 128k of race tune abused when I traded it in. Iíd still rock the 15
__________________
2017 F-250 KR CCSB 4x4- 4400 coils, rear block removal, 20x10 novakanes, nitto 420s, king shocks, OUO traction bars, 5in Alum Driveshaft.
  #49
Old 05-11-2019, 04:29 PM
Major
Member's Gallery
Default
It's rared it's head as low as 530-550. They're just weaker.
__________________
  #50
Old 05-21-2019, 02:42 PM
Sergeant
Member's Gallery
Default
What cold air intake to go with for this? Has a K&N right now, stick with that or get a no limit or something? Got the EZ Lynk with TSD tunes. Seems like I really have to get into the throttle go get to the power/boost, but it moves out good once it hits. I would imagine thats just something to get used to over my 6.0. Other than that, got the exhaust and all the ******s done. Love the thing so far!
__________________
I am a ginger.
  #51
Old 05-21-2019, 04:04 PM
sootie's Avatar
General
Member's Gallery
Default
Throw the k&n out ASAP. I would go with a no limit personally
  #52
Old 05-21-2019, 04:22 PM
Sergeant
Member's Gallery
Default
Sounds good, figured that was going to be the case.
__________________
I am a ginger.
  #53
Old 05-21-2019, 09:01 PM
C2tuck's Avatar
Lieutenant
Member's Gallery
Default
I have the same exact setup and mines spools pretty quick. Have plenty of low end power, only notice power drop off on top end when cruising 80-85 and going to pass someone. Itís there I just want more. Lol.
Could definitely tell a difference when I put the No Limit on.
Also do your cold side pipe if you havenít already. H&S ftw!
__________________
  #54
Old 05-22-2019, 08:15 AM
Sergeant
Member's Gallery
Default
Got the no limit intake on its way, hopefully that helps my kinda strange low end power issue. If not, im sure its just something different than my old truck I have to get used to. What TSD tune are you running? I have to wire in my shift on the fly switch yet, but have one of their tunes loaded. Havent tried any others yet.
__________________
I am a ginger.
  #55
Old 05-22-2019, 02:42 PM
C2tuck's Avatar
Lieutenant
Member's Gallery
Default
Honestly not sure as the shop loaded it. Could be because the switch isnít installed. I normally run in setting 4. Had to switch to 1 yesterday cause it was raining and my ass end kept breaking loose under normal driving.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
Designed by Military Ltd
