"Fuel pressure low" message
Constructionworker
29palms CA
I have a well maintained 2017 with a message of fuel pressure low and immediately followed with the power being cut in half. Before the message pops up I have full power and no odd noises. Truck is bone stock with 65k miles.
Anyone else have something similar?
Mesa, AZ
Do you run any additives, like a cetane boost or something like that? Ive seen it a ton on the 11-16s, where the little cardboard piece in the cap makes its way into the tank, and plugs the pick up. The 17+s are a bit different pump/sender design, but that could be happening.
Constructionworker
29palms CA
Took it to the dealer. They say the fuel filter housing was sucking in air at the water drain valve. We'll see tomorrow when they get it installed. Obviously not covered by warranty. Also had a small coolant leak on the back of the engine something like a coolant plug.
That would do it. Hopefully that was it man!
