Complete 1200HP DYNOED 6.6L Stroker Ford Motor Transmission Setup
Ford stroked
Blaine Wa
Complete Motor & Transmission Setup, Spent Over $42,000, less then 1500Miles, see images & invoices direct from Elite Diesel. Just had a kid and moving onto family projects. Won many awards for highest HP from BD DIESEL DYNO DAYS with trophy's to prove. Ran constant 11 secs 1/4mile times @ over 124MPH with videos and slips this all was done with just Fuel no injectables. Motor is setup with dual waste gates for injectables so quicker times & much high HP ratings are easy possible. I have lot of dyno sheets, videos, trophy's, & obviously invoices. See images attached. priced to sell quickly
$20,999 OBO
willing to sell entire truck. 2008 Ford F-250 EXT CAB SB completed gutted, using oneup off road 3-Link front & trac bar rear Setup, Running 20" Wheels & Near New Nitto 420 Tires. has Clean BC CANADA VIN!
  • Inv_16874_from_Elite_Diesel_Engineering_20780.pdf
Ford stroked
Blaine Wa
Wont find A more complete setup, that's proven, reliable, & priced aggressively.
Make me a offer.
Its basically same setup as JD Gleason has been running. JD & Nathannial from rudys diesel, helped me build, design & Tune!
Ford stroked
Blaine Wa
I have the truck partially disassembled to make lighter for track but have all the parts if you wanted to reassemble to make stock again. wouldn't take much to make it fully functional daily driver again just some time.
Ford stroked
Blaine Wa
its a white super cab short box, just a base, all stock, with 20x10" mayhem satin black warrior wheels and nitto 420 tires. like I said its interior is stripped out for weight reduction but have all parts to put back together. send me you number and I can text you some current pics of vehicle.
Harley-6.4
I’m no expert but the torque number seems a little high for a drag truck, it must be rough on the tranny and the suspension.
Ford stroked
Blaine Wa
over $41k in receipts just from EDE, plus a bunch more from other places, load of spare parts, plus cost of truck, suspension, wheels, tires, add your labour at assemble & install motor transmission. sure adds up to a lot. may not be $168 but I'm sure you get my point.
Ford stroked
Blaine Wa
transmission is complexly built I have two available, ones from EDE never been installed, the one installed at the moment is complete build from Midwest with a DPC converter which is a monster, suspension is a complete oneup offroad setup including 3link, trackbars & rancho shocks.
