Go Back   PowerStrokeArmy > Power Strokes > 6.7 Aftermarket
Reply
Thread Tools Display Modes
  #1
Old 12-03-2019, 06:47 PM
romainchu78 romainchu78 is offline
Private
Member's Gallery
Default CP4 High pressure pump disaster prevention kit
hello, what is the best quality/price prevention disaster kit on the market for a 2012 f250 6.7L ?
  #2
Old 12-03-2019, 06:52 PM
sootie's Avatar
sootie sootie is offline
General
Member's Gallery
Default
Whatever floats your boat. Not really a necessary item imo
Just be careful what you put in the tank.
  #3
Old 12-03-2019, 07:08 PM
ncollins64's Avatar
ncollins64 ncollins64 is online now
Colonel
Member's Gallery
Default
The s&s kit is very nice and well made. I’ve installed several. As Sootie said use good fuel and change filters with motorcraft every time.
__________________
2013 F350 CCSB PLATINUM
08 F-350 CCSB 950/1493
Midwest Diesel, Elite Diesel, RCD, OUO, No Limit Fab, PMF Fab
1997 F-350 7.3, srw, rclb, 4wd, 5speed (work truck)
Past rig: 2000 F-350 ccsb, 1100 hp 6.7 cummins
  #4
Old 12-03-2019, 07:19 PM
Private
Member's Gallery
Default
how many hours did you spent installing it?
are there any cheaper choices than S&S (bit still good quality)?
I buy my diesel fuel from a high traffic Valero gas station. plus i use fuel additive. plus i change my fuel filters twice a year. plus i drain water from tank fuel filter once a month. plus i have a very conservative driving (never any brutal accelerations, try not to exceed 1,500 RPM, do little warm up before driving) but was told the CP4 might still break. my truck has 140,000 miles. i bought it when it had 106,000 miles and i don't know if previous owners took care of it or not. i just can't afford $10,000 in repair for changing the complete fuel system if this happens to break. I would feel more comfortable doing it.
  #5
Old 12-04-2019, 04:19 AM
sootie's Avatar
General
Member's Gallery
Default
Wow you're paranoid.
  #6
Old 12-04-2019, 04:59 AM
HeavyAssault's Avatar
HeavyAssault HeavyAssault is offline
Major
Member's Gallery
Default
I'd suggest you sell your truck to a real man.....he deserves it more than you.
  #7
Old 12-04-2019, 05:30 AM
Zeb Zeb is offline
Lieutenant
Member's Gallery
Default
Its good to try to take care of stuff, but with that driving style youre doing more harm to the emissions system than you are good to the rest of the truck.
  #8
Old 12-04-2019, 07:31 AM
Petro's Avatar
Petro Petro is offline
Major
Member's Gallery
Default
Its a 6.7l V8, not a C15 Cat, some rpm is definitely not going to hurt it and some hard accelation every so often is a good thing. You're not saving anything by driving it the way you are. If you're that worried, I'd suggest buying a gas engine.
__________________
08 F250 CCSB 4x4 6.4 5r110 140k - Tunes, Diet, etc
94.5 F350 CCLB Dually 4x4 7.3 PSD ZF5, 370k - 180/30's, Tunes, etc
06 F350 CCSB 4x4 6.Blow ZF6, 220k - Injectors, Turbo, Fass, currently in pieces
Pulling Truck
05 F250 CCSB 4x4 6.Blow 5r110, 230k - Hybrid 250/100's, S369, RR, Fass
  #9
Old 12-04-2019, 10:38 AM
Private
Member's Gallery
Default
Quote:
Could you please explain that more in details?
  #10
Old 12-04-2019, 11:49 AM
Zeb Zeb is offline
Lieutenant
Member's Gallery
Default
Idling, low rpm driving, etc keep heat much lower in the combustion and exhaust level which increases soot loading.
Soot loading contributes to more frequent regens, lower fuel mileage, and shorter emissions equipment life span.
  #11
Old 12-04-2019, 12:29 PM
PSDJunky's Avatar
PSDJunky PSDJunky is offline
Sergeant
Member's Gallery
Default
OP,
I used to be really worried about stuff like that when I got my first PSD. But, think of what they're designed for. They need to been worked at least somewhat. You basically want to do all your maintenance at the correct intervals, remember your payment/don't beat on it from every stop light, but have fun driving it. It likes getting to and maintaining 190-210 oil temp and 1,700-2,000 RPM for extended periods of time. In fact, it needs it, precisely for what Zeb mentioned. Let it run
  #12
Old 12-04-2019, 02:02 PM
tomlin tomlin is offline
Private
Member's Gallery
Default
Your best move would be to check and see if your auto insurance covers fuel contamination. Water and subsequent rust is your number one killer of these CP 4 pumps. If they cover it, drive it like you stole it. That chances of you having an issue are pretty slim but I understand your concern. 10k is a large amount of dough to fork over for a repair. Add that in with your monthly truck payment and yeah, it would hurt, bad.
__________________
2000 f350 super cab dually
  #13
Old 12-04-2019, 08:25 PM
Private
Member's Gallery
Default
thanks
  #14
Old 12-04-2019, 08:26 PM
Private
Member's Gallery
Default
Quote:
Real man takes care of their Diesel....
  #15
Old 12-05-2019, 05:11 AM
Major
Member's Gallery
Default
Follow my lead then....
  #16
Old 12-10-2019, 09:07 PM
turbodiesel_02's Avatar
turbodiesel_02 turbodiesel_02 is offline
Sergeant
Member's Gallery
Default
Id Invest in a diesel site fuel filter kit before a disaster prevention kit.
__________________
2012 f-250 with a few things
02 7.3 that's not much of an 02 anymore
  #17
Old 12-11-2019, 06:51 AM
CTC DEEZUL's Avatar
CTC DEEZUL CTC DEEZUL is offline
General
Member's Gallery
Default
Quote:
Can you explain? I'm not familiar with how it works? Is it a filter that filters right out of the pump? Cause that's the only way to stop metal from entering fuel system...
__________________
Teamsters Local 444- Rolling Coal United
  #18
Old 12-11-2019, 06:54 AM
Major
Member's Gallery
Default
I was understanding the "problem" is fuel lubricity, not filtering.
  #19
Old 12-11-2019, 07:54 AM
CTC DEEZUL's Avatar
General
Member's Gallery
Default
Precisely. And any filtering isn't going to help once a pump is grenading.... People don't get that the fuel used to lube the internals of the pump is directed to the injection cycle of the pump...
Fuel goes in, lubes cam and rollers, picks up metal, then goes directly to the piston to get pressurized and sent to injectors....
Bypass kit takes that lube fuel and tosses it back into tank. It only stops fuel system from being contaminated
__________________
  #20
Old 12-11-2019, 08:06 AM
Major
Member's Gallery
Default
While I don't have a HPFP to put my hands on I'm asking to gain the knowledge. I'm not trying to argue any particular point.
So the HPFP in stock form uses the same "lube" fuel to inject fuel into the cylinders.
Whereas using the Bypass kit the "lube" fuel is never introduced into the cylinders and has a secondary "clean" feed of fuel to the cylinders.
Is that the right principle of the bypass kit??
So that would leave us to using the OEM filters to capture any shavings/contamination that is "bypassed" to the fuel tank.
Is that correct?
  #21
Old 12-11-2019, 12:15 PM
CTC DEEZUL's Avatar
General
Member's Gallery
Default
Yea but still your pump will fail eventually. If it's sending metal out, it's done. So even after filters catch what's thrown back into tank via the bypass, you've only got a few hundred miles if that before pump grenades.
I'm trying to sell cp3 conversion kits(for DMAX) and FASS systems to customers with good running trucks. That's $5k spent there is alot better than the $11k they'll spend after the pump fails and contaminates the system
__________________
  #22
Old 12-11-2019, 12:33 PM
Major
Member's Gallery
Default
Yea. I found the newer S&S video that gave some internal understanding to the "how it works" of the HPFP. I gathered the biggest point was not that the roller bearing of itself causes the problem, but a two fold event that requires the guide to turn 90* to the cam which causes the roller bearing to now be in a "not as designed" orientation. That is when the most severe HPFP failure issue can occur and happen where the bearing is eaten up by the cam.
I want to say the video gives credence to the air that becomes entrapped in fuel as the possible/principle source of creating the environment to cause the guide to rotate 90*.
I'm not trying to say one way or the other how these failures happen. Just giving info that I gathered from the video.
So with the combined factors of air entrapment and poor fuel lubricity these are key elements of the HPFP failures plaguing the industry. Yes, one can cause the issue just as much as the other, but both issues combined cause a huge issue to rise up much faster.
Does that sound about right?
I would never disagree adding filters, additional water removal, supporting pumps, and air removal are quite effective "insurance" to helping our fuel systems.
  #23
Old 12-12-2019, 09:49 AM
treatcg treatcg is offline
Private
Member's Gallery
Default
Could always upgrade to the Exergy improves stock CP4 pump or Exergy inlet metering valve depends what you want to spend.
__________________
Clayton
2016 F250 Lariat FX4 6.7
  #24
Old 02-24-2020, 12:20 PM
Bigdogdiesel Bigdogdiesel is offline
Private
Member's Gallery
Default
I have a 2011 with 160k and a 2014 with 170k. I have been adding Wal-Mart 2 stroke oil in 85% of my fill ups since new. (Actually starting at 40k on the 11). 1/2 gallon on the 32 gallon tank (14) and 1/3 gallon on the 11 with the small tank 23 gallon or so. No fuel system or *** issues as of yet!
  #25
Old 02-24-2020, 12:36 PM
CTC DEEZUL's Avatar
General
Member's Gallery
Default
Cool. But that doesn't help with air or starvation if your lift pump was to go out.
__________________
  #26
Old 02-24-2020, 08:47 PM
ghohouston's Avatar
ghohouston ghohouston is offline
Colonel
Member's Gallery
Default
From a beloved cp4 today on a Duramelt with 175k. Guy said he got a fuel filter warning, then it just shut down on him. He said he drained some water out of the filter afterwards, and then replaced the filter. Lol.
__________________
1997 F350 SRW CCLB 4x4 ZF5 7.3
2018 Ram 5500 Mechanics Truck
2001Tdi Jetta 5 speed
  #27
Old 02-25-2020, 05:36 AM
blacksmoke.r.us's Avatar
blacksmoke.r.us blacksmoke.r.us is offline
Sergeant
Member's Gallery
Default
Just drive it... I've seen where some people take exceptional care of a vehicle and it has many issues. Then I've seen a rancher who doesn't change oil for years much less fuel filters and it never stops running.
Yes preventative maintenance will help in most cases but in some instances things just fail, no matter how well they're taken care of. Take your chances and do what you feel is right.
IMO like most have already said put good fuel, drain water and drive it. Or you could always go buy a new one with a warranty.
  #28
Old 02-25-2020, 06:47 AM
CTC DEEZUL's Avatar
General
Member's Gallery
Default
Quote:
Oh man I love seeing that. Money in the bank!
__________________
  #29
Old 02-25-2020, 10:34 AM
Connor M's Avatar
Connor M Connor M is offline
Lieutenant
Member's Gallery
Default
Two stroke oil in a cr lol
__________________
2008 CCSB 6.4 Harley Davidson- PPEI Tuned, EZ Lynk, 4" Jamo Stainless Exhaust, Down But Not Out
2008 CCLB 6.4 Lariat Land Yacht- H&S tuned
2008 EC C&C F450 6.4 Work Truck- Almost there
2003 RCLB 6.0 XLT- 260,000 miles, no name tunes, stock as can be
6.0 Dump Trucks- 350 and 450
VT365 Rollback
  #30
Old 02-27-2020, 06:28 PM
ghohouston's Avatar
Colonel
Member's Gallery
Default
Quote:
Not quite. I work for a heavy equipment dealer as a field mechanic. This is a customer of ours and I was asked to go diagnose when they broke down on the highway. They towed it to a local G.M. dealer.
__________________
  #31
Old 02-28-2020, 12:25 PM
CTC DEEZUL's Avatar
General
Member's Gallery
Default
Well what the ****? Give them your number and do it on the side.
__________________
  #32
Old 02-29-2020, 04:31 AM
Major
Member's Gallery
Default
Quote:
You are adding WAY to much oil. I did my own "fuel additive" research....2 stoke sucks in a 6.7L...especially when you track MPGs.
There's other ways to add lubricity to the fuel.
  #33
Old 02-29-2020, 09:37 PM
ghohouston's Avatar
Colonel
Member's Gallery
Default
They make some questionable decisions sometimes lol. It really was a courtesy thing. I thought about it, but don't have the space to do so in an apartment with very limited parking. Once I have a house it'll be a different story.
__________________
  #34
Old 03-08-2020, 05:13 AM
DDRaptor's Avatar
DDRaptor DDRaptor is offline
Private
Member's Gallery
Default
So I use Valero mainly, teat my fuel, and Ford has maintained the truck from day one. 2015 F250 108k on the odometer and my CP4 is finished. I did not know about the issues with the CP4 and ford warranty acted like they would cover it according to the service writer. They found rust a and said not.going to happen. I had the trucked towed to the house because I am.all but done with Ford. Called my insurance company and they sent my fuel off twice with different samples and both times no water was found in the fuel. So truck will sit till I take it to PSE in houston for repairs. Truck has never been abused and always serviced so I guess **** happens.
That being said the disaster kit will be installed on the truck as well.
Sent from my SM-G975U1 using Tapatalk
__________________
2015 F250 King Ranch 4X4 Stock for now...
  #35
Old 03-08-2020, 07:00 AM
CTC DEEZUL's Avatar
General
Member's Gallery
Default
Yup. Just quoted out another on Friday. $10,500...
I have a feeling I'm going to own more 6.7 trucks than I have 6.0s due to customer no fixes. In a few years nobody's going to be fixing 2013 trucks
__________________
  #36
Old 03-08-2020, 07:55 AM
Major
Member's Gallery
Default
So if one were so inclined to just swap out the HPFP before the issues started, how much would you charge for that work??
  #37
Old 03-08-2020, 10:07 AM
CTC DEEZUL's Avatar
General
Member's Gallery
Default
Isn't book hour like 6 hours?
If I had one of these piles I'd install a new pump, the bypass kit, and also a fass fuel system. The air that can come from these stock lift pumps is horrific. We clear lined the feed after the lift pump and every time you key on it gets a surge of air. Also with the dozens of failures I've seen, only a few had apparent signs6of contamination. Rest had clean fuel, I mean they may have ran low or gelled, but usually you can't tell. So that leads me to believe it's air. Both from services and the natural air the pump produces on start up.
__________________
  #38
Old 03-08-2020, 02:03 PM
DDRaptor's Avatar
Private
Member's Gallery
Default
That's an interesting thought there. I agree with the FASS as well the stock water separator is junk. I never changed anything in case I needed to use that expensive warranty. After this I see how I will be treated by Ford I am over it.
__________________
  #39
Old 03-08-2020, 02:22 PM
CTC DEEZUL's Avatar
General
Member's Gallery
Default
Ford knows what their doing. They did it with the 6.4 and their doing it with the 6.7.
__________________
  #40
Old 03-09-2020, 06:09 AM
Major
Member's Gallery
Default
I've been wanting to do some fuel system mods. Just not ready to go at it right now. I have long considered adding on a sump, pusher pump (AirDog, FASS), then swap in a new HPFP.
Currently using a DieselSite filter kit.
  #41
Old 03-09-2020, 05:04 PM
Towerguy Towerguy is offline
Sergeant
Member's Gallery
Default
I wonder how long it actually takes for the problem to become visible, to start exhibiting symptoms and show signs of rusting. Tanks are being checked for fuel contamination but I'm wondering if by the time the truck is having a problem, has the bad tank of fuel already been consumed and refilled at another station? If so, bad fuel would likely be the cause of the problem even if the fuel samples test clean. And also likely the reason that Ford is ignoring clean fuel tests. They probably know the damage was done before the current fuel was ever put in the tank.
__________________
David Frost
2005 F250 Harley CCSB
  #42
Old 03-09-2020, 07:01 PM
DDRaptor's Avatar
Private
Member's Gallery
Default
You know I thought about that to. However when you think out it how long does that rust take to get there. Where is the oxygen coming from to create rust. So most likely wont be in that tank my thoughts.
__________________
  #43
Old 03-11-2020, 06:38 AM
Jonnydime's Avatar
Jonnydime Jonnydime is offline
Major
Member's Gallery
Default
I'm pretty sure one of the guys on here pulled the vcv or whatever is on the rail on a brand new truck and there was rust on it. I could be wrong though as it was awhile a go.
  #44
Old 03-11-2020, 04:40 PM
sootie's Avatar
General
Member's Gallery
Default
Quote:
Yep. Duston did back in 2013 or thereabouts
  #45
Old 03-11-2020, 06:05 PM
DDRaptor's Avatar
Private
Member's Gallery
Default
Thats ford for you they probably install them that way. Hate to be that way, but this situation is bs
__________________
  #46
Old 03-22-2020, 12:29 PM
SDER1 SDER1 is offline
Private
Member's Gallery
Default
Definitely not trying to derail OP's topic, but any thoughts on use of the Exergy CP4.2 Inlet Metering Valve? Found it browsing the web and crosschecked it on a couple vendors for availability, averaging $240.00. Apparently the valve is updated with 25 micron rating, double filter screens (OEM single 80 micron screen), which if a CP4 does fail - the valve will collect debris and prevent fueling the engine/shutting it down.
Wondering if this may be a better option for CP4 failures, considering cost and labor involved with the SS Prevention Kit? Still learning my 6.7, since leaving the 6.0 last summer.
__________________
- Will
2006 F350 CC SB / OEM Air box / Zoodad / SCT / ScanGauge II / MBRP 4" TB w/Kitty MIA / CCV Mod'd / Blue Spring / 6" Fabtech lift (want a 4 or 4.5") /35" FC-II & 18" Moto Metal / Cobra 75WX / Wilson 500
"SOLD"
2017 F350 CC LB / "Stock" / 285/75R 18 Nitto AT G2
  #47
Old 03-22-2020, 02:57 PM
DDRaptor's Avatar
Private
Member's Gallery
Default
Honestly with what I am going through I am looking at both. Would love to put an inline filter between CP4 and fuel rail tip injectors, or one OB the discharge from the bypass kit to collect metal
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
Designed by Military Ltd
