Go Back   PowerStrokeArmy > Power Strokes > 6.7 Aftermarket
Reply
Thread Tools Display Modes
  #1
Old 04-06-2020, 09:44 AM
jimmystoys's Avatar
jimmystoys jimmystoys is offline
Sergeant
Member's Gallery
Default '11-14' Retro Fit or Upgrade?
Hi all. Searched some retro fits and upgrades from the past here but it's been kinda quite so thought to bring it up and see if any ones done anything lately that they're satisfied with. Not looking for a drag racer just want to replace/upgrade my '12 (I think I'm on borrowed time with it 212k lol) with something that's reliable. I have an old S****** file. If this is not a 'chatty' topic anymore, just pm me, thanks.
__________________
-2012 King Ranch CrewCab 4x4 Long box. 14" Lift, 40" Toyos, 4" Flow pro, AFE stage II intake, ******* Warhammer, full ******s.
-2005 XLT Lariat Supercab 4x4 Long box, 10" lift, 38" Trxus Mt's, Edge tuner, full ******s, ARP studs, Airraid. Gone now!
-'79 XLT Lariat F-350 Supercab Long box 4x4, 460, 4" lift. Resto project
  #2
Old 04-06-2020, 11:24 AM
erbear28 erbear28 is offline
Private
Member's Gallery
Default
Quote:
Stock 15+ turbo would be your best bet if you plan on leaving the hpfp alone
  #3
Old 04-06-2020, 10:56 PM
farm boy's Avatar
farm boy farm boy is offline
Sergeant
Member's Gallery
Default
I've been happy with my stock 17' turbo and HPFP upgrade. Although now I think I would have tried the new cheetah turbo that's out there just for the hell of it.
http://nolimitfabrication.com/index....product_id=674
Truck pulls awesome though and has plenty of power for a work truck.
Drags a 20 bale hay van like it was made for it.
__________________
~2013 F-350 6.7L Dually 4X4 {17 Turbo & HPFP, NL Piping Kit, 5" exh & Proven Diesel Tunes}
~2002 F-250 7.3L 4X4 Flatbed
~2014 Toyota Tacoma 4X4
~2004 F-350 Shorty 6.0 (SOLD)
  #4
Old 04-08-2020, 10:30 AM
Wicked Wicked is offline
Sergeant
Member's Gallery
Default
BD just released a new drop in Turbo. It has larger wheels on it but unsure the blade count on the turbine. Might be a good option.
__________________
2019 Platinum F-250 - 6.7L PSD, GDP Tunes, 5” exhaust, NL Stage 2, Carli 4.5" lift, Fox Shocks, and 24x12 TIS 548BMs on 37s
Sold -2000 F-350 Crew Cab - .10 over, Mahle Pistons, Cryo'd Rods, 250cc/100%, 1.15 38r, SRP1, ITP RR, 910's, DI Pushrods, ARP, BDP Live Tuned, BTS Converter+VB+Pump Mods, 5" Exhaust, 4” Lift, and 20x10 Fuel Kranks on 35s
545rwhp/1,243rwtq
  #5
Old 04-09-2020, 07:05 AM
joebuck's Avatar
joebuck joebuck is offline
Sergeant
Member's Gallery
Default
15+ OEM swap is a awesome upgrade!
__________________
2012 CCLB Lariat Ultimate/EZ Lynk/Tyrant Tunes/15+ turbo swap/5” flo pro/H&S upgraded silicone CAC pipe/No Limit stage 2 intake/Mishimoto primary rad./2.5” BDS leveling kit/Fox shocks & stabilizer/Ride Rite airbags/20” XD Grenades/35” RBP
  #6
Old 04-10-2020, 04:41 AM
HeavyAssault's Avatar
HeavyAssault HeavyAssault is offline
Major
Member's Gallery
Default
So I can share info with others.
What is used for the tuning files?? Are they straight OEM files tweaked to use on 11-14 trucks?? Are they "custom" tweaked PCM/TCM files short of being full ****** files???
I tend to suggest to 11-14 people to go with the 2015+ hardware upgrade but rarely hear about that it takes on the tuning side.
  #7
Old 04-10-2020, 07:38 AM
joebuck's Avatar
Sergeant
Member's Gallery
Default
Yes with Tyrant tuning which is who I run they fuel a little heavier down low to get the larger 15+ turbo to light off quicker. It’s not Smokey unless you flat foot it it’s just the way fueling works to keep it less “laggy” from what I understand.
__________________
  #8
Old 04-12-2020, 09:31 AM
jimmystoys's Avatar
Sergeant
Member's Gallery
Default
Quote:
Was wondering if I need to upgrade the HPFP? Your suggesting it's not needed? Probably a good idea to do. I think that's been upgraded too on the 2015's? Or maybe aftermarket HPFP puts out more fuel? Maybe someone can clarify that for me.
__________________
  #9
Old 04-12-2020, 09:41 AM
jimmystoys's Avatar
Sergeant
Member's Gallery
Default
So farmboy you have a '17 turbo on your '13, if i read that correctly. Swap went ok? And what brand of HPFP did you install? I looked at that No Limit turbo. Looks pretty good too mind you it's pushin up to 45psi. Might have to worry about that on a stock set up?
__________________
  #10
Old 04-12-2020, 09:42 AM
Private
Member's Gallery
Default
2015+ hpfp flows more than the 11-14. The 15 turbo by itself on a 11-14 is fine but if your truck has some miles on it it wouldn’t be a bad idea to upgrade to the 15+ pump.
  #11
Old 04-12-2020, 09:48 AM
jimmystoys's Avatar
Sergeant
Member's Gallery
Default
So in my situation I'm running the old S****** tuner with full d*****. Just what we did back then. I am happy with it. It's been good to me. But I think it could be complicated should I need to tweek 'it'.
__________________
  #12
Old 04-12-2020, 09:54 AM
jimmystoys's Avatar
Sergeant
Member's Gallery
Default
Ya probably upgrading would be a good idea once I've committed myself. So should a 2015 and up stock hpfp be used or after market? Can I benefit from more fuel from aftermarket pump?
__________________
  #13
Old 04-12-2020, 10:22 AM
Private
Member's Gallery
Default
Basically your only aftermarket option is a stroker pump but iirc they don’t last as long as a stock 15+ pump but you wouldn’t benefit from a stroker pump on a stock 15+ turbo
  #14
Old 04-12-2020, 10:29 AM
jimmystoys's Avatar
Sergeant
Member's Gallery
Default
So stock pump it is. Thx erbear for the info.
__________________
  #15
Old 04-13-2020, 09:01 PM
Powerstroke214's Avatar
Powerstroke214 Powerstroke214 is offline
Colonel
Member's Gallery
Default
You may not NEED a revision, but you may benefit from it. I had Patriot OST on my 14 and LOVED it, allowed for the tweaking I needed, in your situation without OST you'll need to get a new device.
__________________
6.0 Lariat (SOLD):GH, No Limit, DPC, RDD, PMF, Icon, 20x10 Weld Methods
14 KR (SOLD):PMF, ICON, 15 Retrofit, DC Customs Headlights, Transferflow Tank
19 KR:OUO Steady Track, ALAs, Traction bars, Carli Coils, Carli valved King 2.5 shocks
07 Outlaw: Stock
  #16
Old 04-19-2020, 10:07 AM
jimmystoys's Avatar
Sergeant
Member's Gallery
Default
That would suck if I needed a new device. Quite happy with what I have now. I would hate to do a complete turbo upgrade and struggle with figuring out what or who's tuner to go with. Don't like unprepared changes. Trying to get all my ducks in a row...
__________________
  #17
Old 04-20-2020, 12:39 PM
farm boy's Avatar
Sergeant
Member's Gallery
Default
Yes 17' turbo on the 13'. Swap was done by Powerstroke Enginuities in Houston.
I went with a Factory 2015+ HPFP since I'm not running bigger injectors.
__________________
  #18
Old 04-23-2020, 08:01 PM
jimmystoys's Avatar
Sergeant
Member's Gallery
Default
Ya good to know, thanks farm boy.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
Designed by Military Ltd
