Go Back   PowerStrokeArmy > Power Strokes > 7.3 Tech
Reply
Thread Tools Display Modes
  #1
Old 10-08-2020, 12:30 PM
Big Bore's Avatar
Big Bore Big Bore is offline
Major
Member's Gallery
Default Clearing oil from cylinders after injector R&R
Hey guys, been awhile since I posted here. Finally doing some work on the old 7.3 and new orings and gp's are on the menu. Was refreshing my knowledge and reading some articles, ran across a pdf from Swamps that said blowing the oil out of the gp holes was a no-no and could cause engine damage. I swear I learned that trick from Dave or Jonathon way back on TDS when i bought a set of Babies. I recall the first time I did it was replacing a bad injector from swamps and Tom S was standing there when the vc I didnt put any bolts in blew off and covered everything in oil. Lesson learned, two bolts in vc before cranking, its a lot of pressure. Anyway, Has something changed or is that a cya situation? i've already reinstalled the injectors, removed gp's and about to install vc's and turn it over. Thanks a bunch for any information.
__________________
E99 with some junk and tuned by C-Fro. Building some more junk to put in it.
11B
Quote:
Originally Posted by Powerstroked162 View Post
... I don't want to be left assuming you're a dipchit. I want you to prove it to me...
  #2
Old 10-08-2020, 12:48 PM
79jasper's Avatar
79jasper 79jasper is offline
Colonel
Member's Gallery
Default
Spin it by hand. (Put a socket and big wrench on the crankshaft pulley bolt)
Sent from my SM-N960U using Tapatalk
__________________
2003 F250 KR SCSB FX4
Depleted, studded, airdog (which isn't currently hooked up), fass regulated return, airaide, 4 inch straight pipe with mbrp muffler(so on to go), glowchit pyro, fuel, boost, and trans temp. (Of course don't work lol) Hercules terra track A/T2 315/70/17.
2013 Honda pilot Touring
http://badges.fuelly.com/images/sig-us/778639.png
http://badges.fuelly.com/images/sig-us/776628.png
  #3
Old 10-08-2020, 01:23 PM
Big Bore's Avatar
Major
Member's Gallery
Default
Thanks. Do you happen to know what the possible issues are turning it over with starter?
__________________
11B
  #4
Old 10-08-2020, 02:15 PM
CJunkie's Avatar
CJunkie CJunkie is offline
Corporal
Member's Gallery
Default
You can, will generally make a bigger mess though. I prefer doing it by hand too.
Sent from my LM-V350 using Tapatalk
__________________
97 F250 SCLB 7.3 4x4, 303k and counting
zf5, 6637, TS chip, dual 4" straight pipes
Currently looking for axles for an 05+ swap.
  #5
Old 10-08-2020, 03:17 PM
dsberman94's Avatar
dsberman94 dsberman94 is offline
General
Member's Gallery
Default
Go by hand to get the bulk out then you can turn over by starter. If you try with the starter and thereís more in the cylinder than can come out at a given rate you could mess up the valve train.
__________________
02 F250 7.3 Crew Cab Short Bed Lariat
PHP Hydra, Ge4rhead tunes, Edge insight CTS monitor
Mild Trans Build, Dual disc TC
GTP38R, T500, PIS 175/80s in the engine. waiting to see rods one day
Turned 200k miles 1/18/2015
  #6
Old 10-08-2020, 03:51 PM
Arisley's Avatar
Arisley Arisley is offline
Mod Squad
Member's Gallery
Default
I always go two full revolutions by hand. Then snug the valve covers and bumb the starter, don't go steady crank like you are trying to start it.
__________________
E99 ECLB Dually, 2010 bed, 2005 headlights, smoked clearance lights, 2001 cup holder.
365,XXX miles. Pure stock, sorta.
SDRCM #478
PSA Conspirator # 22
  #7
Old 10-08-2020, 09:59 PM
Big Bore's Avatar
Major
Member's Gallery
Default
thanks guys for all the info.
__________________
11B
  #8
Old 10-09-2020, 06:21 AM
Strokersace's Avatar
Strokersace Strokersace is offline
Colonel
Member's Gallery
Default
Are you guys really serious?!?!? Iíd have expected better knowledge out of you fellow ďexperiencedĒ 7.3 guys. By hand, then use the starter? Mess up the valve train? COME ON!! Work smarter not harder!
Big Bore (sorry man I canít remember your name as itís been YEARS! Frank is it?), do it how youíve always done it!! So long as thereís oil in the bottom of the engine to lube the rotating assembly, you wonít have an issue. There is NO compression in any cylinders, so even though Berman has apparently reverted back to his dipwad days, it wonít cause issues with the vavletrain at all!
Throw a few bolts into each VC, keep the 42 pin connector unplugged so the idm isnít commanding fuel injection, and bump the starter several times. Pull covers, clean up any messes as oil drips off them, reinstall whatís left, and change the oil for good measure since it now has raw fuel in it from the injector swap, then go drive the piss out of it to get the air out of the system!
If Iíve done one 7.3 injector swap this way, Iíve done 30 (maybe more) over the years. Never once have I (and likely hundreds of other people) EVER had a problem only bumping the starter to evacuate the cylinders.
__________________
I'm sweatin' like a wh*re in church here!
  #9
Old 10-09-2020, 06:45 AM
79jasper's Avatar
Colonel
Member's Gallery
Default
I've done it from the starter on the few I've done. Kept being told "it was wrong."
__________________
  #10
Old 10-09-2020, 02:50 PM
Lt.Dan's Avatar
Lt.Dan Lt.Dan is offline
Sergeant
Member's Gallery
Default
I too have done it with the starter, tiny bumps, nothing big. I did remove a couple bent pushrods a couple days after... i wonder if that was why.
__________________
1996 Cali F350 DRW CCFB, 7.3/E4OD, 2wd SAS w/ 392,000 miles, rebuilt at 352,250.
2018 F350 DRW, 6.7/6R140, 4wd w/ 34k miles
  #11
Old 10-10-2020, 01:06 PM
Big Bore's Avatar
Major
Member's Gallery
Default
Yea man, it's been a few years, you got it right.
I've done it that way several times with no issues but I'm also aware I might have been lucky lol, and I just can't afford to break things right now due to tight schedule and a long road trip ahead so I guess I'm more nervous about things like this than I used to be. I don't mind taking a little extra time to roll it by hand a few times, cheap insurance.
__________________
11B
  #12
Old 10-13-2020, 08:04 PM
lincolnlocker's Avatar
lincolnlocker lincolnlocker is offline
General
Member's Gallery
Default
Better safe than sorry..
Ine of those brake bleeder canisters work great also. Just stick the tube down into it and shake it around a bit so it doesn't just seal to the top of the piston then put vc on and bump starter. Im to broken in my old age to do much Armstrong chit anymore so i find easier ways to do stuff. Might take longer but thats my life now.
__________________
00,f350,4x4,cc,drw. Sold... good bye ole girl. I will miss you
15,f350,4x4,cclb, not stock
  #13
Old 10-16-2020, 10:30 AM
tomlin tomlin is offline
Private
Member's Gallery
Default
Look at it this way, take a full bottle of Dawn dish soap, open the lid and turn it on its side and squeeze it. Soap will flow out the tip. Now, take the same bottle and quickly stomp on it and note the carnage. The soap bottle is your engine. Hydrostatic pressure can be devastating if it happens where it shouldn't.
__________________
2000 f350 super cab dually
  #14
Old 10-16-2020, 11:07 AM
Addicted4 Addicted4 is offline
Lieutenant
Member's Gallery
Default
I think this is being way over thought.
  #15
Old 10-16-2020, 09:10 PM
ghohouston's Avatar
ghohouston ghohouston is offline
Colonel
Member's Gallery
Default
Imo if you remove the 1/8th inch allen plugs under the valve covers, let the oil rail drain like you're supposed to, and then remove the injectors, you don't get that much oil/ fuel in the cylinders. I have replaced at least hundreds if not thousands of heui injectors, and have not had a direct or indirect issue afterwards from cranking the engine with gp's removed and 42 pin connector disconnected.
__________________
1997 F350 SRW CCLB 4x4 ZF5 7.3
2018 Ram 5500 Mechanics Truck
2001Tdi Jetta 5 speed
  #16
Old 10-17-2020, 08:21 AM
Colonel
Member's Gallery
Default
Quote:
Way WAy WWAAAAYYYY overthought.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
Designed by Military Ltd
