Go Back   PowerStrokeArmy > Power Strokes > Aftermarket Super Duty 1999 - Current
Reply
Thread Tools Display Modes
  #1
Old 11-24-2011, 03:23 PM
01platinum's Avatar
01platinum 01platinum is offline
Major
Member's Gallery
Default Boost Gauge Pickup
Got a good deal on a AFE Turbo Spyder to replace the stock one on the truck. I am going to remove the boost fooler that is on the truck now since I don't need it and I am wondering where the best spot would be to tap into to get my boost readings. On the afe there are 4 plugs that can be removed but they are on each side going into the intake manifolds so I didn't think that would be a good place since I will only be reading one side.
I have done the IH ****** and have been looking for the plug with the threaded hole for the boost gauge but no luck. I am replacing the stock plenums with the ones from WOP. So since I have to pretty much remove everything in the valley I would like to clean this up since it will be removed. Won't get started till next week so I have some time to pick things up if I need to.
01Platinum's Command Center
__________________
2001 Platinum Edition
Mods: Changing everyday
SDRCM#999
  #2
Old 11-24-2011, 10:25 PM
01platinum's Avatar
Major
Member's Gallery
Default
Bump since I know there are guys with a boost gauge piped in some where else.
__________________
SDRCM#999
  #3
Old 11-26-2011, 12:48 PM
Ron's Power Stroke's Avatar
Ron's Power Stroke Ron's Power Stroke is offline
Lieutenant
Member's Gallery
Default
use the plug thats on the same side the passenger IC pipe goes into..should be about the same place the AIH would be on a stock Spyder..that will give the reading right where it splits going to each head...you also still need that boost fooler...
__________________
Early 99 7.3 F350 auto,TN T-4 mount with a s467 thanks to unlimited diesel..beehives, DI push rod's, new alliant 315/200 hybrids, Driven diesel fuel system with a fuel lab 41401...tuned by ********..
88 F250 7.3 IDI plow truck 112k- bone stock
  #4
Old 11-26-2011, 12:52 PM
01platinum's Avatar
Major
Member's Gallery
Default
Do you know where to get a plug that has the fitting for the boost gauge to plug into?
__________________
SDRCM#999
  #5
Old 11-26-2011, 12:57 PM
Lieutenant
Member's Gallery
Default
i thought it came with fitting but maybe not..i dont know the size of the fittings.. but if it was me,i would take the fitting out of the Spyder and grab the fitting for the gauge and head to a parts store...im sure they can help you out..
__________________
  #6
Old 11-26-2011, 12:58 PM
neverkickn's Avatar
neverkickn neverkickn is offline
Colonel
Member's Gallery
Default
Just get an autometer gauge install kit at your local auto parts store. It will probablly have a bunch of various fittings including a 1/8" npt compression fitting that you can use to tie your boost gauge line into the maniflod. Assuming that the manifoled is tapped for 1/8"
__________________
14 f250 cclb xl....stock
01 f250 scsb xlt....modified and still slow!
  #7
Old 11-26-2011, 01:05 PM
TyCorr's Avatar
TyCorr TyCorr is offline
General
Member's Gallery
Default
A brass npt freeze plug would thread into the hole that the AIH was. Then you take your same drill bit, same tap that you used to install your pyrometer probe and drill/tap the brass plug. Put a 1/8npt fitting in the new hole you tapped and hook up your boost reference line going to the gauge.
Or you could tap the compressor housing and put the fittin right in there....
__________________
IW local 393
  #8
Old 11-27-2011, 01:26 PM
Dmstrucks02's Avatar
Dmstrucks02 Dmstrucks02 is offline
Colonel
Member's Gallery
Default
Will this work? I dnt know how the afe is set up
http://www.riffraffdiesel.com/mm5/me...de=F731-IN-AIH
__________________
02 CCSB X code leafs with full traction hangers on 35s
Stock motor, stock trans with TransGo valve body mods, Mishimoto trans cooler
Full Force 238/80's, Irate Diesel T4 kit, S366SXE
OUO weld on traction bars
Texas Tuned
5" MBRP
Isspro gauges
  #9
Old 11-27-2011, 10:51 PM
01platinum's Avatar
Major
Member's Gallery
Default
Yes that will work. Now what color??? Haha thanks
__________________
SDRCM#999
  #10
Old 11-27-2011, 10:58 PM
01platinum's Avatar
Major
Member's Gallery
Default
Guess I should have posted this so you had an idea of what I got. Like I said I got a smoke'n deal on it. Not the price listed by a long way.
http://afepower.com/shop/details_new...sel&brandID=25
__________________
SDRCM#999
  #11
Old 11-28-2011, 12:19 AM
Lieutenant
Member's Gallery
Default
looks to be about the same size hole as a stocker..if it is, it will be a 22MM X 1/2 thread, it can be drilled with the R drill bit that was left from your pyro install and tapped with the 1/8" NPT tap that came from same install..i think this was the same as an oil plug for the cumaparts..you will also need a crush washer or an oring to help seal the plug..this is how i did mine and it cost under 8 bucks..
__________________
  #12
Old 11-28-2011, 07:03 PM
Colonel
Member's Gallery
Default
I would say black or bare aluminum
__________________
Texas Tuned
5" MBRP
Isspro gauges
  #13
Old 11-28-2011, 11:22 PM
01platinum's Avatar
Major
Member's Gallery
Default
I ordered the black one. Ready for it to get here so I can install the intake plenums and spyder. Going to be an interesting day is all I can say.
__________________
SDRCM#999
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
Designed by Military Ltd
