I was thinking of going with RBP 96Rs and Nitto Trail Grapplers with these dimensions on; (see pics below)
RBP 96R
Size 22x9.5
Bolt Pattern 8x170mm
+10 Offset
5.75 in. Back Spacing
Black Machined Finish
LT325/50R-22
Black Sidewall
Load Range = E
Max Load = 3305lbs.
Tread Depth = 20/32
Overall Diameter = 34.92
Now I was wondering if this would all fit without rubbing. I have a Leveling kit.
I dont want to put fender flares on nor do I want to go any higher than I am already!! I prefer a clean cut truck as apposed to a cop grabber! Its bad enough already with my custom tune!! 525rwhp/1020Torque. Thats the reasoning for the offsets and backspacing dimensions. If this doesnt work I was thinking of;
96R Series Wheel
Size 20x9
+10 Offset
5.5 in. Back Spacing
Pro Comp xtreme MT
35x12.50R-20
Black Letters
Load Range = E
Max Load = 3195
Tread Depth = 20.5/32
Overall Diameter = 34.6
Now the original wheel I know is 20x8 with a 6" offset... I figured id post this and see if anyone has perhaps tackled something like this. All info is much appreciated! Its about due time to give her new boots
O I also came across this chart that might help others out
http://www.readylift.com/t-tire-calculator.aspx
RBP 96R
Size 22x9.5
+10 Offset
LT325/50R-22
Black Sidewall
Load Range = E
Max Load = 3305lbs.
Tread Depth = 20/32
96R Series Wheel
Size 20x9
+10 Offset
Pro Comp xtreme MT
35x12.50R-20
Black Letters
Load Range = E
Max Load = 3195
