who made their own trac bars
8luggin
mechanicsville virginia
Who has made their own trac bars looking to build my own while I have some free time artwork. Thinking some 1 3/4 dom tubing and some 7/8 rod ends
MINK
London,OH
I've run nothing but homemade bars on my previous truck and my 6.4 will be getting a set here soon. I've you have the time and ability then I say go for it.
Dieselboy.
Surrey B.C.
Use 2" steel with a 1/4 wall thickness. I order 1.5 inside diameter and used a 1 1/2 threaded collar for my Johnny joint or heim joint. That was a 1" thread with a 9/16 hole for the bolt. Made the mounts for the frame and axle and welded them on.
Ballistic fab I believe sells the heim joints and bushings, grease nipples and such.
Dzchey21
wyoming
i made my own out of tubing, i also made a traction block similar to ouo when my truck was lifted and stock height for the dpc
Rene G
Did you have to change the length of the bars for different hights?
p.s. even your frame mounts look almost exactly like OUO's, nice bars.
Lowdown89
Travelers Rest , SC
Is their a specific formula for how long they need to be? My friend wants to build a set for his megacab and I want to build a set for my CCLB dually... Most sets I see look to follow the angle of the driveshaft should I make it long enough where I stops at the carrier bearing or longer? I remember seeing a thread a while back where there was a lot of good info but I searched and couldn't find it
Also i would to make it a totally bolt on affair so some ideas for Making it bolt to the axle instead of welding would be great
