jwlandry
3" flex. Probably 3' worth and 2 clamps.
Ordered the T4 OBS kit, IC boot kit and a BASB from Jake (Irate) last week. Waiting for it to arrive. There was a delay because the BASB had to be built by Pius (Bell Turbo). I also told Jake to make the DP longer and I will cut it to length.
Billy T.
[email protected]
Is it up and running yet?
Rusty
Yes it is. Nice kit but if it wasn't for the DP, it would be a bolt on kit. I don't understand why the stock replacement DP are made to work and Jake can't do it on his DP.
I tried bending the firewall but I failed. I just jammed the DP in there so I can drive it. The BASB turbo spools very easily, cleaned up the smoke and the EGTs dropped. I didn't get on the truck because of the DP hitting the firewall. When I get it back, I'll report back.
I dropped off my truck at my chassis guy to fix the DP. I told him that I would really like a 4" DP :evil. He told me that he would try. I told him that I'm giving him the go ahead to cut the firewall to make it fit.
Also my chassis guy is going to tweak the IC pipes so they line up a little better and fix the turbo to intake pipe.
I let Jake know that he should raise the bellows on the passenger side to gain more clearance.
To get the truck running, I connected some flex to the DP and connected it to the exhaust.
This is my chassis guy's air ride OBS. He built the suspension from scratch.
http://www.jwracing-fab.com/forum/viewtopic.php?t=147
Billy T.
[email protected]
Billy T.
[email protected]
Keep your eyes open for some OBS stuff that will be going up for sale shortly. The OBS IC pipes have been sold already.
Billy, I was wondering if you had made a for sale thread yet?
will the DynoProven dp swap in? will they sell it seperate?
I bought a stainless lower Diamond Eye 162003 and welded a section to Irate upper to connect the pieces in a spot you can actually tighten the band clamp
as the outlet of th eturbine is only 3" I dont thinnk there is much gain increasing the pipe to 4", but my truck has 6" stacks so it goes up and up after the dp
