gnxtc2
Does anyone make a breather that can take the place of the oil filler cap? Maybe from a Mustang or other Ford performance vehicle?
Billy T.
[email protected]
Billy T.
[email protected]
mass produced? or just one someone made at home? either way, ive never seen it..Does anyone make a breather that can take the place of the oil filler cap? Maybe from a Mustang or other Ford performance vehicle?
Billy T.
[email protected]
Are you thinking this might benefit? Like a built gasser?Does anyone make a breather that can take the place of the oil filler cap? Maybe from a Mustang or other Ford performance vehicle?
Billy T.
[email protected]
Like a gasser.
Was thinking that the breather nipple on the driver side is around 1/2". With the stock PCV setup, the crankcase was under negative pressure.
Now we eliminated the plumbing into the turbo intake and vent to the atmosphere. I can't see how a 1/2" nipple could evacuate the crankcase pressures.
I was thinking about getting another extension tube and cutting the top threads off and clamping in a breather similar to this.
Thoughts
Billy T.
[email protected]
stinkyLike a gasser.
Thoughts
Billy T.
[email protected]
stockish is fine... most of the issue is at higher hp and rpm where it can't evacuate it fast enough.So, hope I don't sound too dumb... Are we saying that venting cc pressure to atmosphere is not suffient enough? I guess What are you saying the positive effects of venting the other side with vacuum (ie exhaust) would be? Are you still planing to maintain the normal ccv mod plus this, or this in place of the normal ccv mod?
stinky
