Cts 2 back up camera
theronbt
Bremen, Ohio
What is everybody running as a back up cameras on cts2? I have saw some posts saying you can use a cheaper camera then the one edge has.
Lipka101
Maryland
Yep. I got mine on ebay. $15 iirc
I have the cts but im pretty sure it's the same video input cable.
Koda22
Ruidoso, NM
Yea I'd like a little more info on this....have a back camera up to the radio, but would like to do a front mount camera on the edge is possible....easier parking.....but I've only got the original edge
Central Illinois
Don't have a camera now. I would really like one for backing up to trailers instead of getting out 4-5 times to see where I'm at. If the camera is only $12 and reliable it seems like this is the route to go.
GregW
KY
I'm not using it with a CTS, but when I installed my radio I used this camera:
http://www.amazon.com/Esky-EC170-06...&qid=1460463826&sr=8-6&keywords=backup+camera
It was $20. This is the one with the parking guidelines. They offer the exact same camera without them. Picture quality is great for a backup camera, and it does pretty decent in low light as well. I have mine wired so that it's on anytime the truck is on so I can view the camera anytime I want. Been setup this way for a year now without any problems. It's perfect for backing into tight parking spots or hooking up to trailers.
As an Amazon Associate we earn from qualifying purchases.
GregW
KY
I'll grab a few pics after work. I bought the OEM Ford emblem for the tailgate that has a place for the camera. I think it ran me around $60, plus the $20 for the camera listed above. A lot cheaper than the $300 the dealer wanted for the emblem and OEM camera.
GregW
KY
Sorry, forgot to post the pics when I got off work. Here's a few.
GregW
KY
The only issue with mine is you can see the top edge of the emblem in the frame. I just need to tweak the bracket to fix that. But I just use mine for hooking to trailers and getting in tight spots, so it's not an issue
Lipka101
Maryland
Sorry just saw this. Mine looks similar to that on my edge cts.
I pulled the factory camera out of the tailgate handle. The one I posted in the link is a little smaller so I had to do some redneck engineering, I wrapped enough black electrical tape around to hold it in place then put a bead of Silicon around it on the back side for a more permanent solution, and last I got some black gasket maker to clean up around the outside edge.
I'm sure I could have fabbed up some kind of bracket to hold it in place but it's been well over a year and I haven't had any issues.
Central Illinois
Ordered my camera today. Question I have it when you have it plugged into the the cts will it automatically come up and turn on when you put the truck in R or is there some other options that need to be switched on the cts?
nighthawk285
La Grande, Oregon
When using a CTS/CTS2 you only need to make the connection and it'll automatically go to the camera screen since it reads gear position through the OBD2 port. I have mine in the handle....very handy for making trailer connections
