Cutting-Edge Diesel
Talking with a few companies. Going to talk to some in person with a piston in hand at pri in a few weeks.
That thing will need trophy truck shocks to take the beating of a Mississippi road.
Maybe add air ride on the trailer?
Talk to Drew @ D&J at PRI. He will be there...may be worth the talk for piston ideas
Awesome!Already been talking with him![]()
It already has shocks and thats more than most any other trailers. I just needs chassis stabalizers to keep the car from bouncing.
how did the show go?heading to PRI show today. Dropping off the block with Drew at D&J precision machine, p pump and injectors are getting dropped off with Dan Scheid to get checked out. And taking pistons to Mahle booth to see what they say.
Doing a lot of work to the internals of the injection put to increase reliability. Runaways are a lot more dangerous in drag racing and dan was concerned about failures inside the pump during the run. So we are micro blurring all moving parts and rebuilding the governor weights to make the thing run smooth and not surge.
We are also getting new nozzles made up run a tighter spray pattern. Dan thinks there is more power to me made with this change. Super excited to get it on the dyno.
Going to add a guillotine? Or just carry a shop manual and hope you can get to it fast enough? Or is shutting off the fuel supply to the pump enough?
