post your hp and dyno info.
Status
Not open for further replies.
Redneck6.0L
Won't be a problem cause the 6L ones are coming with the 90deg bent so the stock uppipes will bolt on. I'll post pics when they get here
Redneck6.0L
Didn't I call it like 20 pages ago he wouldn't post vid of it LOL
windrunner408
Yes you did.
Chris,
Yea thanks. I emailed them and the $900 is for the manifolds with a ceramic coating. The only down side i saw was that new up-pipes have to be made because they dont bolt up the stock ones.
Pizza pig
In the Brig (Banned)
MD
those are the 6.4 versions, the 6.0 versions have the 90* for the uppipe
strokin6L
Springville NY
like said. The 6L manifolds from steedspeed will have the 90* bends bolted to them to that they'll bolt to the factory up-pipes.
windrunner408
I guess even the ones with 90* wont bolt up. He said the reason was because they have a 2.5in diameter outlet whereas the stock uppipe is 2.0in I guess. I am just going with what Leen Steed told me is all.
strokin6L
Springville NY
to bad that they couldn't make them to bolt up to the factory Y-pipe. Now a guy has to fab up a new y-pipe if he was to get a set of these. Just not something most guys will want to end up doing to run these manifolds.
windrunner408
Seems like it would just be easier to modify the stock ones rather than make all new up-pipes. That would definitely be a little bit beyond my limitations right now.
Jwarren
That was the whole point of this thread, so guys can read what others are actually makeing for hp. There's been just way to much crap being thrown around on psn and the org about inflated hp #s. For example Frank put 180s and a powermax on and he's selling his truck cause its not what a 6.4 is on a max tune. Which makes 550. One maker which way you slice it a powermax and 190s won't make 550hp. Now some guys with 62,64 non vgts are making 550 with track times/mph to back it.
Don't be shy guys, this thread isn't to discredit anyone. We have all been disappointed with dyno/track #s. So share so others can see what is working
He should have went 205 / 75's and a 64/71/80. That'd walk a tuned 6.4
Sent from my LG-P925 using Tapatalk
Redneck6.0L
The manifolds Kevin was promised two months ago still haven't been shipped. So I'd mpd full of crap or what
Craig@MFI
He knows that we've been waiting on manifold material for a month now
Mike@MPD
Pasadena,MD
You need to watch your mouth there buddy with all the calling out. Its getting a little old. When they are done they will be sent. Mind your business and when he gets them let him review them. Thank you. That is all
Sent from my Droid Charge
Redneck6.0L
Watch it or what. What's your 4foot butt gonna do. Ehhh maybe carigs mommy and daddy can buy a body gaurd for you togo with craigs truck who's registered to his mommy
Status
