sunrisefordparts
zf5 bolt set that holds the case halves together? (S5-42 4x4 if it makes a difference)
the bolts that hold the transfer-case to the zf5 tailhousing?
thanks
case bolts list $1.67 each sell $1.25 each x17
transfer to trans bolt list $2.75 each sell $2.06 each x8
quote # 263308
01 7.3 water pump and install kit
2000 f350 dana 60 front differential (complete and/or rebuild parts), inner and outer axle seals too
shipping cost to 49631
sunrisefordparts
Zf5 (S5-42) overhaul kit with synchros.
Zf5 master/slave cylinder assembly
clutch pedal assembly
clutch pedal list $109.77 sell $82.33
master/slave cyl list $216.08 sell $162.06
ford doesnt offer an overhaul kit, its sold in parts as needed
quote # 263476
TurboM700
Minnesota
Just sent you an email but I'm looking for a price on a Tourqe Converter for a 01 F-350 7.3l
Vin 1FTSW31F41EA75137
Thanks
Mike
Slayvok
Hi, could I get a quote for part #4C4Z-7004302-HA with shipping to area code 95973. Thanks!
