6.7 carnage
Powerstroke586
Eden, Utah
I guess I should go ahead and add that the turbo kit from Industrial on this truck uses a s400 charger. Not sure where I came up with a K31 now that Im looking back on it. If I recall though the first twin kit they had in testing used that charger, I even think we had a thread about it on PSN, I'll have to look. Regardless, the production based kit comes with an S400 atmosphere, to correct a previous post I had made in here.
I also heard that Crower is making rods for these engines and there are Mahle replacement pistons available as well. Absolute also has pushrods ready for you 6.7 boys as well :D
A kid i work with has the industrial kit on his 6.7 and said his is an S400 as well, and from what i hear its a horribly put together kit.
He did 580 corrected yesterday on adrenaline diesels superflow, claims he did 656 on custom autos dyno but most people are always higher on that dyno from what i gather. Says he is getting rods and pistons along with a pump and injectors, im guessing from industrial.
He daily drives his everyday and hasnt broke anything yet, he also never gets on it cause he is scared to throw a rod.
was the truck in these pictures just cruising or did he have the pedal to the floor when it broke?
powerstrokedub
Utah
Is this the red 6.7 I have seen around?
slc dzl
Riverton, Utah
There is also a black one out here that im told is also
Running there compounds and injectors, is this the truck?
JDub
Hooper, Utah
yeah the dyno he was on usually gives people 60 to 80 more horsepower. to put it into perspective an intake tune and exhaust 6.4 made 664 on the same dyno LOL
It made that power cause it was my old truck man...it has Jacoby magic in it :swordfight:
On a side note- Sounds like the A1 Head Stud kits for the 6.7L should be just about ready. The two test sets they sent to us weren't quite right, but it sounds like they're making the needed changes.
Powerstroke586
Eden, Utah
Thats true! every truck you buy is a power house!! :rockon:
Nos_GTSR
Rexburg, ID
Dyno was reading pretty accurate at industrial. Dunno what its been doing since. Its been correct then way way way off.
