20x12 on stock height trucks
STRAIGHTSTROKEN04
I was hoping you would chime in, I loved the look of your old truck. 20x12s machined fuel hostages it is. Now nitto 420's or mud grappler... Decisions decisions.
MINK
London,OH
You need a square tire to make it look good.
I'd do either the Toyo M/T or Nitto 420s if you want the more street look.
Jarrod B
Corpus Christi Texas
jdsf350
southwest wi
I have an 08 350.. how high do i have to go for them to work? I can deal with alittle rubbing. I have already decided on 20x12s just hoping I can fit 35" without a 4in lift. Not afraid to do some cutting if i have to with a leveling kit. Probably going to try either way. just seeing if anyone else has done it.
Strokin6.4
Ill most likely be doing 22x11 or 20x12s with 35s and a 2.5" leveling kit. I'm pretty sure it will work
B.Warning
NE Missouri
I never tried it at stock height but 20x12 w/ 35" will clear with a leveling kit with very very minor trimming.
wanna_b
I haven't had my wheels off yet to see how much to trim but is there enough threads to be safe?
MINK
London,OH
I cut mine so I could run 1.5" spacers - that was painful enough and I regret not just buying a wider wheel from the get go.
I wouldnt advise to cut much more if any..
