06 F250 New short block
HuSlungDu
Helotes, TX
Then I decided to port the intake
HuSlungDu
Helotes, TX
Here are the previous pictures that have photobucket links. I was told some people could not open them.
They should be in order.
HuSlungDu
Helotes, TX
Truck sitting on the lift for a month and Engine build starting.
HuSlungDu
Helotes, TX
Heres the 66mm Turbo sitting on the CED divided t4 up pipes.
The kit went together good, had a slight clearance problem with the downpipe hitting the passenger side up pipe. With a little persuasion of my bfh on the downpipe, I was back on track. I was happy about my Magnaflow 4" because it was a true 4" all the way to the turbo, until this point, now I wish I had ordered an MBRP.
HuSlungDu
Helotes, TX
Here she is all put back together minus the coolant filtration
HuSlungDu
Helotes, TX
Every new truck with a new engine should get some new shoes, dont you think?
Dalton_H
Had around 210k on it. Truck had lots of red dirt on it when he got it so I'm guessing it just never got air filters replaced and dusted the motor.
