Northwoods2002
I've done the searching, but want to double check my plan of action before digging into it. 2002/F250 320k miles on 7.3/4r100. Truck will start when cold, or sitting longer than an hour or two. Running it 1/2mile down the road to fuel up, if you shut it off it won't restart, you have to let it cool down again. Problem started last week. No distingushable smoke while cranking but can hear fuel pump running. Things that have been done over the past 6-8 months whether routine or not:
New batteries
Fuel bowl, hpop, IPR, turbo all rebuilt
New valve cover gaskets
New starter
Things done since issue arose:
New cps (didn't have a spare anyways)
IPR resealed (internal oring was damaged)
Fresh oil change with valveoline blue.
I do not have the ability to look at Pids so I am assuming my next course of action will be to remove valve covers and (hopefully?) Find the Injector(s) that are leaking oil? Any other suggestions? I have a buddy I could take it two to look at Pids, but I'm not sure if it will make the 30min drive as the last time it happened I was actually going down the street and it just died...
New batteries
New starter
