powerjoke4life
- Joined
- Dec 27, 2011
- Messages
- 731
- Reaction score
- 0
I have an 03 6.0 it has zero power, will nearly do 50 mph and has the hardest time getting there. It has studs and a 4" exhaust. Stock other than that.
I had a cylinder contribution code so I checked for bubbles in the fuel and there was. So I replaced injectors. Got it all done fired it up and it still has no power.
I ran it around the block and it still has no power. I am not getting any codes. What could it be? Oil pressure is good, I broke the nipple off the MAP sensor so I put a new map sensor and hose on.
What to check?
What to check?
