03 turbo Question
peixinho
it is hard to tell from the video... are you pushing in and out or side to side?
A little side to side is ok (some of it will go away once the oil fills the turbo)
In and out is really bad.
I have seen many "rebuilt" turbos with worn out backing plates. If the backing plate is worn then no rebuild kit will help. You have to replace the backing plate
peixinho
touching the housing is not good news. If you are able i would pull the turbo apart and check out the internals.
The thrust collar should not move around in the backing plate. Also if it is freshly rebuilt it will be pretty obvious when you open it up
