Power Strokes
04 6.0 Bad PCM?
[QUOTE="okie, post: 1500417, member: 7184"] To update my issue above, it was the pcm. I'm guessing between the egr and the throttle valve short I later found it cooked the pcm. For anyone else troubleshooting, take your multimeter and check for continuity between the 5v reference and ground on the icp sensor. That's the easiest and quickest place to check. If you do have continuity unplug the engine connector from the pcm. If you lose continuity the pcm is cooked, if you don't lose continuity it's in the engine harness or one of the sensors with the 5v reference. Sent from my SAMSUNG-SM-G890A using Tapatalk [/QUOTE]
Latest: Mark Kovalsky
58 minutes ago
6.4 Tech
Latest: 03f3507.3
Yesterday at 2:11 PM
Engine and Drivetrain
Latest: ToMang07
Yesterday at 7:28 AM
B
No Start help
Latest: bismic
Yesterday at 7:04 AM
Latest: 6.0 Tech
Wednesday at 8:24 AM
Ford Power Stroke News
full throttle
LivinAnAdvntr
bismic
Power Strokes
04 6.0 Bad PCM?
