Hoping ya all can give me a bit of advice. I have a 2004 F350 with a 6.0 A while back it suddenly developed a substantial oil leak, it was running down the back side of the engine. I replaced the hpop cover seal thinking that's where the leak was but I seem to have been wrong.
With it running and climbing all over it it seems like it's either leaking from the oil return line off of the turbo or the front of the hpop cover. Here's what's got me confused:
It doesn't leak a drop if the rpms are over about 1k. If the rpms are lower than that there's a lake of oil under the turbo. Does this point to one spot leaking over another?
I'm going to go start tearing it down, kinda hoping to find a torn o ring on the return pipe so I don't have to pull the intake off again, but it is what it is. I'm thankful for any advice.
