Hey there , started from starting and it does instantly after a few crank it starts and runs great , now it's getting worse , checked the fuse good , checked the inertia switch not tripped ,my fuel pump isn't working , so I checked for voltage shows a 10-11v only so thought if it has voltage not 12 but close the pump should already make a sound, replace the fuel pump and I primed it couple times then didn't hear the pump anymore, same thing , I heard the relay for the fuel pump is integrated in with the fuse block under the steering wheel so I turned the key on and gave it a quick hit and the fuel pump started cycling, then I start it right up let it run for a bit shut it off and again no fuel pump , knock the fuse block again started cycling after a bit It stop , does it sound like a bad relay since it has the po231 secondary fuel pump circuit low? Before I buy another fuse block?
Thanks in advance
Thanks in advance
