sleeps
while driving, it drives great, just while idiling it will die just like someone reached over and turned off the key. no studder or anything. rarely it will rev up but only has happened a couple times. it dies at almost every red light or stop sign if i sit there too long. if it keeps moving its fine.
i assumed it was the ficm so i ordered one. its supposed to be here tomorrow, but i also ordered an insight cts to check some things that my sct tsx wont check. well, ficm voltage doesnt drop below 47 while cranking but fluctuates between 46 and 49 volts while idling. didnt see it drop below that under wot. icp pressure is ~580 at idle. fluctuates around there. iirc around ~570-590. anything else i should check? i got an ficm performance code a couple weeks ago but hasnt came back up since. how else should i check the ficm voltage?
