Well, was gonna pay a buddy/shop to do my headgasket job, but money is not where I thought it would be, and have access to a car to get me back and forth for this week. So change of plans... while still doing everything right of corse I gotta get the ball rollin asap.
Without a lift, my options are to do the h/g's in truck, or pull the engine. Going to pull the engine so I can get at my sweaty rear main and put lifters in it (140k on the clock, just for a piece of mind)
My boss is cool enough to let me pull it all apart/put it all back together at my shop where all my tools are at so that's cool, (im a heavy on highway diesel engine mechanic) plus have an overhead crane that goes in all directions.
Buddie that use to be a powerstroke guy at a local ford dealer a few years ago is convinced that pulling the engine for even just the hg job would still be less **** than to try and do it in the truck.. He hasn't done it in a while so that's why im here for any pointers anyone that's done it can give me.
plan is:
suck the ac down
drain radiator/engine coolant
pull fan/radiator/condenser/cac
pull inner fenders
pull hood
pull turbo and oil filter housing
pull up pipes
pull ac compressor and power steering pump
pull starter
unbolt torq converter
unbolt trans
unbolt motor mounts
yank er out..
What am I missing? I mean I get its all just nuts and bolts, its just weird how its got me all intimidated. . . lol, overhaul a 25,000$ engine that's ALOT more picky about being flawlessly clean and bearing clearances are likely a lot tighter on nearly a weekly bases. I don't know why this should be that bad, but I guess its just the fear of the unknown.
any pointers are appriceated.
plan is:
suck the ac down
pull inner fenders
pull hood
pull up pipes
pull starter
unbolt trans
unbolt motor mounts
yank er out..
