Dirtclod
I did this conversion 3 years ago and used the plug &play connectors. The factory connectors were cutoff and adapters thrown away. I've had it pretty close except the drivers side low beam didn't work and it really wasn't that bright. Today I tore it apart and I couldn't get my head around it. I've finally found what I hope is a good diagram. All I want is to be able to put the wires to factory and get the adapters to plug in. Here's what I've found so if anyone knows correct me.
High beams LG/BK
Left low DB/WH
Right low DG/OG
LH turn LG/WH
RH turn WH/LB
Parking lights BN
Fog lamps are Tn/OG
Now I have a continuous hot up there in the mix and my fogs don't get power. Is there a relay up there for fog lights?
High beams LG/BK
Left low DB/WH
Right low DG/OG
LH turn LG/WH
RH turn WH/LB
Parking lights BN
Fog lamps are Tn/OG
