06 ebp normal readings
Diesel625
Cruising on level ground at 75mph I get 33.5 psi, light acceleration 40-45, hard acceleration in 6th I get 47. These values are off the scangauge.
Mesa, AZ
Seems fairly normal. That’s 19ish psi cruise, 30ish on accel, and 32 at wot, which is around max gauge readings,
bismic
The ScanGauge will read MAP sensor numbers.
Boost is just MAP minus Baro (barometric pressure).
