10" lift 99 f250
cg21
I am looking at purchasing this lift
http://www.pmfsuspension.com/19995-04-10-Alpha_p_93.html
Anyone have any experience with it? Any special tools needed? Anything I should look out for when doing it myself? I have never installed a lift kit before. Any tips or advice would be greatly appreciated.
Also what would be a good tire size? What are you guys running with similar lift?
Thanks have a good one.
rescuejg
10" lift is a lot.
Is it your intent to run 40" plus tires?
You will probably have to lengthen your driveshafts and do some custom work to the center carrier bearing if your truck is so equipped.
Lengthened brake lines.
Maybe some custom work to the e brake cables.
Probably a bunch of other stuff that I'm not thinking of.
Sent from my SM-G973U using Tapatalk
DEEZUZ
NO PUKESTERS
NWI
