10" lift front driveshaft question
Strokinn6.0
New jersey
What has anyone done with there front driveshaft at 10". Is there a longer slip yoke/high angle yoke available any info appreciated
florida 6.0
florida
I had mine lengthened at a local driveline shop and then rounded all the sharp corners on the yokes and joints with a grinder for a little extra clearance .
Dalton6.0
I have 10" lift stock front driveshaft with no problems and I know multiple other people as well
Tonka350
Melbourne florida
If you're worried about clearance instead of grinding you can always use a pmf transfer case clocking ring and cross member. ...
Spoolin'
Florida
Ive done nothing to my front drive shaft with 10". Seems to be fine. 4x4 works as well.
