11-16 mirrors
Dirtclod
Pilot Mtn. NC
This may not be in the right place. I'm pretty sure they don't have an adapter for power folding and telescoping mirrors for 99-03 trucks. Has anyone installed these and have them working?
Diesel X
A1 Auto has mirrors. Part # 1amrp00611 maybe what you need. Has adapter plug, but you will need to run wires for heat, signals and running lights.
rosspulliam
DFW
I have them on my 02 using factory switches. The are a few details here. I get home later today and will post more details there. Long story short on a 99-02 truck you'll be pulling 8 new wires into each door. As you get newer with each feature you can drop a wire (turn signal, clearance, heat,etc) from the 8.
If you want the electric adjuster to work you've got to use the new switch and do some wiring there too since the up/down/left/right got all swapped sound in the later trucks.
