2 SD forged engines & 70K mi 4r100
co04cobra
WV
I have a L99 and an E99 for sale complete turbo to oil pan. Both were in running trucks until I sold the trans' out of them.
The L99 is a factory ford rebuilt engine with around 150K on miles. E99 was in one of our yard trucks. It started and ran excellent no matter how long it sat miles are right at 200K.
Either one for $2250 complete or will consider selling just long blocks. PM me.
Also have a 70K mile 2wd 4r100. Complete with converter $1200. It does have a crack at the front trans line. If you can fix it or know somebody that can Ill sell for $1100. Or for the $1200 I will have it fixed. PM me with ?s. Thanks.
co04cobra
WV
All PMs have been answered. I will also consider partial trades for other psd stuff ie: performance injectors, turbos, or possibly tires and wheels. PM me.
co04cobra
WV
Late night bump. Can put on a pallet to ship or work with meeting somebody in surrounding areas.
co04cobra
WV
Also have a forged 99 long block up for sale. Needs head gaskets and injector cups. Should be perfect for a build. $500
co04cobra
WV
would you ship the long block to ia 50023?
Yes will work with shipping any of it. However I pulled the heads on the e99 block and looks like it has a cracked cylinder wall. If you think you can still use it or need a more complete engine shoot me a pm. Thanks.
co04cobra
WV
Bumpin this up until I can start a new thread.
Have a E99 long block complete. Heads looked good. One of the cylinder walls looked cracked upon closer inspection. $500
Also, 02 7.3 complete turbo to pan. Motor started and ran, but has low compression in 3-4 cylinders. Sell off the core stuff and have a cheap block to start a build. $1200
PM me with any ?s Thanks
co04cobra
WV
Pulled a L99 forged rod 7.3 today with 170K on miles. We replaced it do to what appears to be ether damaged pistons. Compression #s were 300-325 it ran fairly well when warm, but no start when cold.
Complete long block $800
PM me with ?s
co04cobra
WV
What does someone do with a $500 motor with a cracked.cylinder?
Use the heads, rods, pistons and crank. Then make the block in to a nice man cave table or living room center piece LOL. Its worth $300-$400 bucks just to have an old block around to fab stuff up on.
