2003 6.0 swapped to 7.3
Animalguy10
Hey guys I bought a previously swapped 2003 f350. 6,0 taken out and 7.3 put in. Drives good
Previous owner told me the overdrive light on the shifter flashes because of the swap. I do have over drive.
I’m curious as to why it flashes ?
Thanks in advance
webb06
Seneca, MO
Thanks in advance
Check the code
Mesa, AZ
Is it still running a 5r or was it swapped to a 4r as well?
Mark Kovalsky
SE Florida, USA
It flashes because codes have been stored. Get Forscan and read the codes, then you'll know why it's flashing. And you may even be able to fix it.
co04cobra
WV
If the swap was done right it should have zero to do with the OD light flashing.
