Non - Specific
Truck Audio
2006 Crew Cab
[QUOTE="jdc753, post: 757484, member: 52"] No... just no, size of the sub does not dictate clarity, that is a old wives tale, or may have applied years ago. Yes the cone is heavier and moving more air so by physics it does seem plausible, but in the proper box and proper power it isn't truth. Especially for the JL shallow 13". Those goes along the same lines as a sealed box is for sound quality and a ported box is for SPL competition. Key to tighter sound is the box, a smaller box acts as a tighter spring on the woofer increasing power handling (to over come that spring) and decreasing low end output. Conversely a large box will improve low end response as it is a "loose spring" and increase overall output but decrease power handling. I believe the closest spec to be looked into for a sub to be "muddy" is the Le which I believe is a measure of the subs transient response or motor strength (I forget) But the JL shallow really is a top notch sub just a tad pricey, but if the budget is good for you then it really is a top notch option to squeeze bass into these tight trucks. [/QUOTE]
2000 7.3 stalls, wif, wts, and ses lights come on
Latest: 6.0 Tech
Yesterday at 10:56 PM
7.3 Tech & FAQ
450 performance issues
Latest: 6.0 Tech
Yesterday at 10:55 PM
7.3 Tech
04 ex w/low hpop pressure
Latest: gwunter
Jun 5, 2024
7.3 lift
Latest: Charles
Jun 4, 2024
7.3 Aftermarket
02 F250
Latest: ToMang07
Jun 4, 2024
7.3 Tech & FAQ
Non - Specific
Truck Audio
2006 Crew Cab
