2006 F-250 6.0 Power Stroke – Brakes Applying Themselves After Replacing Hydroboost & Master Cylinder
Douglasville GA
Alright, I’m at a loss here and could use some input.
I’ve got a 2006 F-250 6.0 Power Stroke, and after replacing just about everything in the brake system except the ABS module, I’m dealing with a weird issue. After a fresh bleed of the hydroboost and master cylinder, everything feels fine at first. But after driving a mile or two, the brakes start applying themselves—not all at once, but enough to be a problem.
Here’s what’s been replaced:
Hydroboost (OEM from Ford)
*Master cylinder (Aftermarket from O’Reilly’s, since OEM is discontinued)
*Brake lines, calipers, and pads
Now, here’s where it gets interesting: if I loosen the two nuts securing the master cylinder to the hydroboost, the issue goes away, and I can drive it back home with no problems. That makes me think the pushrod might be preloading the brakes and possibly needs a spacer.
Has anyone dealt with this before using an aftermarket master cylinder? If so, is there a universal spacer that fixes this, or is there something else I should be looking at? Appreciate any insight before I start throwing more parts at it.
Thanks!
Edit: the problem started with replacing just the mastercylinder. It wasn't until after that I noticed the hydro boost was leaking in the cab and believed that to be the issue. Sadly it wasn't.
Mesa, AZ
Thanks!
Seen it a couple times, the pushrod in the hydroboost may be adjustable, pulled the master back a little and see if you can adjust the rod. Can’t remember what the clearance spec is, but 1/16 of an inch would probably be a good starting point.
I had to do this on my fox body when I put a 95 master on the 93 booster when I converted to 4 wheel disc.
Douglasville GA
The push rod is not adjustable. I've researched that too. Haven't come up with anything. I believe this design is meant to work hand in hand with an oem master but they discontinued the and Ford doesn't provide (at least my local for dealers don't) provide a viable aftermarket option. I was told to "check one of the big three parts stores". 😂
Mesa, AZ
Maybe the master was built incorrectly, try warrantying it out, and see if that fixes it
Tiha
Super Moderator
Super Mod
I had a very similar poblem. Ended up being the pushrod was too long. I had to make one a little shorter. Can't remember how much. Seems like I shaved 1/8" off of it.
hated shaving it because it affects pedal travel, but I didn't have a choice. It fixed it.
Everything would seem perfect, then when it got warmed up the brakes would start to apply.
one other situation I have seen was on an old jeep, the brake line was run next to the exhaust. exhaust would heat the fluid, fluid expands, applies the brakes. But hopefully your exhaust is on the other side of the vehicle.
