2008 F-350 6.4 Power Stroke, crank/no-start
Wafried2290
PA
Truck has had an intermittent/progressive starting problem. It would crank a long time before starting, then eventually reached the point where it cranks but won't fire.
Low-pressure fuel pump has been replaced. I'm getting fuel/pressure through the low-pressure side, but two different people have scanned the truck and both found essentially no fuel rail pressure while cranking.
I'm trying to determine whether I'm looking at the HPFP, VCV, PCV, excessive injector return/leak, air entering the fuel system, or something else before throwing an expensive HPFP at it.
What tests would you perform next, and what rail pressure/PIDs should I watch while cranking?
Mesa, AZ
Check all the fuses in the battery fuse box. There’s a tab for the hpfp cover gasket harness shorting to the hpfp cover and blowing a fuse. Can’t remember the fuse number off hand though
DEEZUZ
NO PUKESTERS
NWI
74. I look for it Everytime one comes in on the hook $$$$ gravy job.
But that's a one and done type deal.
With any 6.4 that has a fuel issue I take fuel sample straight from the rail and if there is glitter I just call it... Needs an entire system....
