Powerstroke Man 6.4
- Joined
- Jan 10, 2012
- Messages
- 4,039
- Reaction score
- 3
I was looking through the 2017 manual on the ford website, and I found this.
Is it a CCV filter of some sort or?
Coalescer filters are typically used to remove oil or water from a gaseous medium, natural gas processing plants use them to remove lube oil from the sales gas stream.
I believe Ford is using it on the CCV system to remove engine oil to prevent it from entering the intake tract.
If this is correct that would be awesome, so no more oil in the CAC tubes etc?
that's great and all , but how about the hot gases ?
CAT used them on the 07 ACERT truck engines and most of the earthmoving/ CCE stuff have them. We generally change them far before the interval says, because they'll get plugged up.
When I had a 2012 Ram w/ Cummins I gutted mine and vented to the atmosphere. My biggest complaint was that it would drip oil out of the hose when parked overnight.
With the amount of blow by that the 6.7 Powerstoke has, I am amazed that I haven't seen any oil drops yet, but I did stick the hose inside the frame this time.
