2018 F350 AC blower not workimg
DEEZUZ
NO PUKESTERS
NWI
Combined with your other issue I'd suspect you have rodents. Chewing on your soy based wiring.
Any chance of this? Mice, shrews, squirrels, etc in your area?
DEEZUZ
NO PUKESTERS
NWI
I've had more 2015-2023 trucks in here for chewed up wiring than I have in 16 years of any trucks older than those.
Smokin 6.0
Indiana
Back to this I changed the pigtail for the blower with a new OEM ford. I checked voltage at the connector and have 12v. I got a new blower and same thing. Can someone explain what the 3rd signal wire does. I even changed the control buttons with a whole new panel I had laying around and same issue
Smokin 6.0
Indiana
So it keeps working and then not. When it doesn’t work I can turn the fan speed all the way up and the fan will ramp up and down with the speed of the truck as wired as that sounds. Any ideas ?
Smokin 6.0
Indiana
Back to this I took it to does and they said it was a blown fuse. Unlikely. Anyway it was replaced and worked for about 2 months now it’s back at it again. Checked all fuses and nothing is blown all relays work also. Taking it back to gird to look again. I checked the blower motor connector with a meter and I have 12v on 1 of the terminals but I’m not sure what that terminal is. When you plug it in it goes away. Unplug and it’s there. So I held my meter on it when I plugged in and it’s there until it makes connection with the blower motor ????
