20x10 & 20x9 Offset and Back Space Question(s)
bperry83
Truck is a 99-04 F250. Going to be going up 6" with 35/12.5R20 Toyo MT's.
1) Which wheel would stick out the MOST past the fender? Second most? Third most?
Offset: -24
BackSpace: 4.50"
or,
Offset: -12
BackSpace: 5.00"
or,
Offset: +0
BackSpace: 5.00"
2) Is there much of a lip on a Fuel Hostage 20x9 with +0 offset and 5.00" Backspace?
3) 99-04 F250 lug pattern is 8 lug 8x170mm?
Thanks guys!
F15CrewDawg
Goldsboro, NC
Took me a while to find it but TANK'S 250 had a post with some good information about this.
http://powerstrokearmy.com/forums/showthread.php?t=10943&highlight=factory&page=2
Given the information he provided, and assuming you have the 8" (I believe) factory wheels with a backspace of 4", I edited your post below. This is for the wheel only, the tire will most likely be wider than the wheel.
Offset: -24
BackSpace: 4.50"
This will move the lip of your wheel out approx 1.5"
or,
Offset: -12
BackSpace: 5.00"
This should be close to the factory offset so the lip would stick out about an inch further.
or,
Offset: +0
BackSpace: 5.00"
This one would move the lip out about 1 mm
A 9" rim with 0 offset should have 3(ish) inches of lip, accounting for the depth of the core material.
I believe that 99-up is 8x170. Some one with more knowledge might chime in and correct me.
Thanks guys!
This has a sticky in the wheel/tire thread but I'll link it here for you. Very useful for just this sort of thing.
http://rimsntires.com/specs.jsp
