Power Strokes
7.3 Aftermarket
5r/6r trans swap
[QUOTE="Big Bore, post: 463900, member: 760"] I never used low range on the road so I couldn't tell you, but I never needed it. I had a ZF5 and 4:10's when I was towing heavy a lot. The only time I used low range was backing up a heavy gooseneck or moving it around on a rough/steep terrain jobsite. If I were planning on doing a lot of heavy towing again, I would do a SD/7.3/ZF6 and 3:73's. I've towed heavy with the 4r and 3:73's and it does ok, but I just didn't like the way it felt with the rpm changes between gears being more than I like. Maybe it will feel different with the compounds if I can hold a higher gear and keep egt's down. [/QUOTE]
Latest: ncollins64
Monday at 7:08 PM
6.4 Tech
Latest: HeavyAssault
Sunday at 3:43 PM
Sunrise Ford Parts
B
No Start help
Latest: bismic
Sunday at 9:58 AM
Latest: 6.0 Tech
Saturday at 11:12 PM
6.4 Tech
Latest: 03f3507.3
Friday at 2:11 PM
Engine and Drivetrain
Arisley
C2tuck
Power Strokes
7.3 Aftermarket
5r/6r trans swap
