EDP
- Joined
- May 30, 2011
- Messages
- 162
- Reaction score
- 0
We have been getting many questions and concerns involved in the topic, so we decided to give some info that many have been mis lead upon.
Empire Performance Engineering in conjunction with GoGo Diesel/Direct Injection have worked diligently together to deliver a solid solution. To surpass all the current knock offs and issues of previous concerns that have arose.
The 5R110 TorqShift transmission is one of the most robust transmissions ever offered in a medium duty pickup. It does however have a weakness. The 5R110 transmission is controlled through the use of solenoids to turn on and off gears. A gear is commanded by the computer and a solenoid applies fluid directly to that clutch. In stock power applications the stock solenoid is fine. Outside of that range, the factory piece cannot provide enough fluid to the clutch fast enough to get the clutches together in a short enough time. Long term slipping of the clutch leads to failure. Direct clutch is not only used for 5th gear in the transmission, but it is also used when in reverse as well. All solenoids are modified from brand new parts and are then tested in house on a Solx 2000 Solenoid tester.
Many have got there hands on the original GoGo Solenoid and believe that they been able to by pass the source, bench-marked, relabeled and repackaged it turned it around marked it up and re sold it. Many have even gone to the extreme as still labeling it as a GoGo/Empire Part when it has not been modified to the standards we have set. Recently we where overwhelmed with the mass orders and ran out of inventory for a couple weeks and was approached by a customer to have us install his Solenoid that he purchased off line and was under the assumption that he was purchasing a solenoid of the exact same. Needless to say the customer is not very pleased with the information that we where forced to inform him about.
You will notice in the pictures we have provided of the differences along with the facts that many people out there using this tactic to drive sales there way with no knowledge of the actual functionality of the part or solution. Many will take the Ford # on the base of the solenoid and simply think they have the in source and re label for a discounted price when really all they are purchasing is a knocked off part. This has been going on since the first part of March of 2013.
This is not a bash thread or looking to come down on any one shop in particular just pointing that more is done then meets the eye of a part number, and beware on who and what you are buying in the diesel world for Diesel Performance . com shops open up on an hourly basis.
-Main things to notice by the naked eye to be sure you are getting what you pay for is the coating on solenoid.
-Bottom Fluid passages have been modified.
http://empiredieselperformance.com/...neering-5r110-modified-direct-clutch-solenoid
