I plan to convert my truck to 4X4 soon and it appears that the out put shaft may be the same as the 4X4 version only slightly longer. Can anyone confirm this? Does anyone know the diameter and spline count of 2wd and 4wd out put shafts??
It looks as if you could cut the shaft off and slide the T-Case on and bolt it up.
