Got some issues with my project truck.
Truck was wrecked, trashed the radiator and pumped all the fluid out
I bypassed the radiator and filled the transmission up. Ran and fluid level is good but the trans wont do anything no gears at all from what i can tell. The cable is broken so I'm doing all this by hand under the truck and then starting it basically in gear with the wire on the fender...
I did have some codes but i forgot them so ill have to get the list tomorrow. I do know one was for the output speed sensor... figured it should at least go into gear but wont shift if the sensor is the issue
I suspect it might be the pump, this truck got towed, supposedly on a rollback but i cant confirm that is a fact.
Any help would be cool, im transmission dumb when it comes to this, i know why they break under power... this stock stuff is foriegn to me lol
