bgrimm1
What is everyone's suggested tranny fluid to run in the 5r110. Just finishin up th tranny w/ suncoast kit and RCD converter just wantin to see what fluid is workin the best
Not MERCON, only MERCON SP or MERCON LV. MERCON will kill the solenoids.
Just another example of the wrong fluid causing problems.Used LV in a turbo 400 once because I had a surplus of it... Had time to read the newspaper between shifts. Dumped all of it and put D3M in it and it was a totally different trans.
Transmission fluids are not like engine oils. You can't use the latest fluid in older transmissions without expecting major problems. Fluids have frictional characteristics that vary a lot. If you use a fluid that is too slippery for the friction material (clutches and bands) in the transmission they will slip. It only takes a short time of slipping before the transmission is toast.
Your experience doesn't mean MERCON LV is a poor fluid, it means a Turbo 400 wasn't designed to use MERCON LV.
