01REDSTROKER
just a little back ground info.
2005, deleted 6.0. no tuning
good ficm voltage
truck ran great, not issues other than a minor case of sticking spool valves that rev-x took care of.
Drove truck about 100 mi. home, let it idle while i unloaded gear.(no issues)
next morning went to leave, started it and it just chugged white fuel smoke.
pulled injectors and sent out and was told 4 of them had cracked nozzles.
installed injectors,new standpipes and plugs and checked fuel pressure, it had about 48. installed blue spring and it jumped to 60. went to start and it took longer than another injector install start up i have done.
it will start if you give it "gas" and lots of cranking. but blows tons of black/gray/ white smoke and will not idle on its own.
good ficm voltage
