SlowSmoke
I had a guy bring me an 06 6.0L to work on. Ford told him he needed a new turbo, and i didn't ask any questions. I put on the Industrial PowerMax turbo and a 4" Flopro exhaust. Took the truck for a drive and seemed ok, but didn't put my foot down. Installed an SCT Livewire with the pyro and went out for a drive. Took it easy till it warmed up then put my foot into it, and once you hit about 3/4 throttle it startes coughing like the injectors are cutting out and it's getting super hot. I changed the fuel filters and no different. Loaded it back to stock and it's still doing it, and i can hit 1450f pyro temps easy with the stock tune in. It gets even worse at WOT. Seems to me like a bad injector or bad HP oil pump? Maybe there is an oil leak going into an injector? It gets worse as the truck warms up which makes me think it's an oil issue. Truck has 150,000 kms on it. Anyone had this issue or know how to check this out? Thanks in advance
